Author Topic: Central Convenience Module Swap  (Read 29868 times)
Offline rex
  • -Given: 50
  • -Receive: 74
Re: Central Convenience Module Swap
« Reply #15 on: February 24, 2015, 10:58:15 am »
Thank you, Eddie!
I will try that when I get home.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #16 on: February 24, 2015, 06:28:53 pm »
Not working :sad1:.
Any other ideas, please? :ashamed:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #17 on: February 24, 2015, 07:03:14 pm »
Just code the module with 819002085103087F2D02040570085AC690BC00
then code it back to what you have now
Cluster and Key coding
Location Great Yarmouth
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #18 on: February 25, 2015, 08:51:34 am »
Still not working  :sad1:
Offline Llew
  • -Given: 45
« Reply #19 on: February 25, 2015, 11:28:32 am »
Did you get to put a steering wheel module in
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #20 on: February 25, 2015, 01:02:07 pm »
No, I have the OEM one.
I am not sure I need one. Do I need another steering module?
Offline Llew
  • -Given: 45
« Reply #21 on: February 25, 2015, 02:43:09 pm »
Doesn't look like u need to change I have a 5 door I'll post up my code see if that helps
Offline Llew
  • -Given: 45
« Reply #22 on: February 25, 2015, 02:54:51 pm »
989008085103087F2D000F0FF0085FC6F0A440 This is my 4 door coding
My steering and instruments are the same as yours
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #23 on: February 25, 2015, 04:23:27 pm »
Still not workink. :(
Could you please give me the coding for the other modules?
Offline SI-R32
  • -Receive: 126
« Reply #24 on: February 25, 2015, 04:29:27 pm »
Do you get the lights and vision menu from the cecm?
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #25 on: February 25, 2015, 04:33:43 pm »
Nope... No extra menu :(.
Offline SI-R32
  • -Receive: 126
« Reply #26 on: February 25, 2015, 06:16:28 pm »
OK so another few questions that may not sound related,  do you have a 510 or similar that displays audio and or nav in the highline
Can you flick through various screens of anything or only the on board computer
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #27 on: February 25, 2015, 06:55:44 pm »
Yes, I have a RCD 510.
I can't access anything on the bord computer except the normal consumption, distance, speed warning, etc.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #28 on: February 26, 2015, 11:33:39 am »
Could someone who has this working post the whole scan of the car?
I am trying to find out if there are issues with the CAN Gateway, Instruments, etc
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #29 on: February 26, 2015, 11:39:03 am »
that won't fix it
the issue is with the module
disconnect the battery terminals and hold them together
