October 16, 2026, 11:27:40 pm
All Things Mk5
Mk5 General Area
Throttle position sensor fault
Topic: Throttle position sensor fault (Read 10719 times)
CRAZY CATH
Always Involved
-Given: 4
-Receive: 1
February 15, 2015, 07:00:54 pm »
glow plug light flashing have about half power vcds says
16611 throttle pedal position sensor g79 signal too low
16610 throttle pedal position sensor g79 implausible signal
Is this a easy fix any one know him much a new one is
doylebros
Just look at my post count
-Given: 44
-Receive: 310
Re: Throttle position sensor fault
Reply #1 on:
February 15, 2015, 07:26:02 pm »
To help you'll have to give more details
Vehicle type
Engine code
Year
Manual or auto
CRAZY CATH
Always Involved
-Given: 4
-Receive: 1
Reply #2 on:
February 15, 2015, 07:31:43 pm »
2005 bkd 5door hatch
2.0 tdi gt
6 speed manual
doylebros
-Given: 44
-Receive: 310
Reply #3 on:
February 15, 2015, 07:45:51 pm »
The part is chassis number dependant you need item 17.
There is a know problem with the wiring rubbing through and grit ingress - plenty fixed the fault by removing the pedal cleaning or repairing the wiring and reinstalling!
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1725&ein=2005&f=420&hauptgr=1234567890&hg=7&grf=072170409&bf=72170&hgug=721&ug=21&parent_id=2018620
1K2 721 503 AJ is the current part £92:52 full retail inc vat
doylebros
-Given: 44
-Receive: 310
Reply #4 on:
February 15, 2015, 07:48:42 pm »
If your going to do the repair this is worth a read
http://workshop-manuals.com/volkswagen/golf-mk5/power_unit/4-cylinder_injection_engine_%282.0_l_engine_direct_injection%29/fuel_supply_gas_operation/electronic_power_control_%28epc%29/removing_and_installing_accelerator_pedal_module/
CRAZY CATH
Always Involved
-Given: 4
-Receive: 1
Reply #5 on:
February 15, 2015, 07:50:19 pm »
Thanks for your help I will tear it apart in daylight see what I can find and repair if I can
Thanks again
All Things Mk5
Mk5 General Area
