Author Topic: ABS, TRACTION CONTROL & TYRE PRESSURE LIGHT ON DASHBOARD  (Read 4517 times)
Offline natalietaylor91334
« on: February 16, 2015, 09:19:42 am »
I own a mk 5 gti. these lights have appeared on my dash board yest but cant get it into garage til tomorrow. anyone had this problem before and can shed any light on the problem?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: ABS, TRACTION CONTROL & TYRE PRESSURE LIGHT ON DASHBOARD
« Reply #1 on: February 16, 2015, 09:36:37 am »
you would need to get it scanned with vcds to see what the faults are. have you disconnected the battery recently?
« Reply #2 on: February 16, 2015, 09:56:00 am »
not recently but we changed rear brake pads and calipers few weeks ago if thats anything to do with it?
Offline TaylorGTi
« Reply #3 on: February 16, 2015, 10:02:14 am »
Hey, iv just had this fixed. I got a g44 fault code which was a corroded abs sensor ring. Had to replace the whole rear hub which fixed problem! Vw don't so any good will on this code btw as I phoned them to find out.
R-tech Stage 2+ Pirelli Gti
« Reply #4 on: February 18, 2015, 08:05:34 am »
ive just had a diagnostic done: 00287 ABS wheel speed sensor rear right G44 electrical problem in circuit.
Offline Danbear79
« Reply #5 on: February 21, 2015, 06:09:58 pm »
Same thing happened to me. Changed both rear bearings and sensors while I was there. The rings on the back of the bearing were kaput. Easy enough to do, you'll need an m18 spline socket and a basic tool kit. There's also 2 options on rear bearing size. Most common are 30mm. Obviously you'll need to scan it for fault codes first, but my money is on the bearings. Also you'll need to torque the bearings back up to the correct  setting
