Author Topic: Headlight Aligning  (Read 1698 times)
Offline MKV_Sean
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,100031.0.html
Headlight Aligning
« on: February 19, 2015, 03:40:14 pm »
Chaps,
Need some advise on this. I recently put on a set of Apex coilovers on my mk5 Gti and its sitting about 30mm lower than normal. I also have a set of genuine Xenon lights fitted to the car from factory and the car will be going in for its NCT/MOT test in the coming week.
My question to you guys is would my headlights need to be aligned after dropping the car? And if so can a normal garage do this or does it require vcds?
VW MK5 Gti DSG 2.0 TFSI
Offline dom069
Re: Headlight Aligning
« Reply #1 on: February 19, 2015, 07:45:25 pm »
You'll need Vagcom to reset them, where in the country are you? There might be someone nearby who can help.
BC Racing Coilovers : R32 Rear Bumper : Milltek Cat Back : R32 Rear Lights : S3 Brakes : Colour Coded Side Skirts : US Grill : 18" BBS CH : De-Wipered : Bluefin Remap : Pipercross Filter : S3 Short Shifter : Powerflex Wishbone Bushes : MK6 Steering Wheel : RCD510
Offline MKV_Sean
« Reply #2 on: February 19, 2015, 07:46:44 pm »
Had a feeling I would. I'm out in Dublin, Ireland. I hope the garage would have access to vagcom if I can't find anyone local
Offline dom069
« Reply #3 on: February 19, 2015, 07:57:32 pm »
Offline AliGTI
  • -Given: 28
« Reply #4 on: February 19, 2015, 11:36:22 pm »
Chaps,
Hiya. Sorry to change the subject slighgly but are you in the UK? I'm looking to fit the R32 Zenon style lights to my GTI. I see lots of American GTI's with the Zenon but not UK???
Offline dom069
« Reply #5 on: February 20, 2015, 11:31:52 am »
Chaps,
He's in Dublin, it says just above :wink:
Xenons were an expensive option in the UK.
Offline MKV_Sean
« Reply #6 on: February 20, 2015, 11:38:19 am »
Offline D_Philli_82
« Reply #7 on: February 20, 2015, 12:44:07 pm »
Correct me if I'm wrong as I may be stating the obvious but can't you just use the auto leveller switch next to the light switch..?!
MK5 1.9TDI 150Bhp
Offline MKV_Sean
« Reply #8 on: February 20, 2015, 12:47:48 pm »
That's only on the halogen models not xenons
