Author Topic: 6 week old Battery dead  (Read 4105 times)
Offline Airz182
« on: March 20, 2015, 09:55:28 pm »
Put a new battery on my car around 6 weeks ago, so the other say i decided to take by front calipers off front grill and splitter off and paint them. So car has not been in daily use for a week or so. Whilst car has been sat in axle stands, i decided to fix my oil leak which i thought was coming from my oil pressure switch, undone it and retightened it. Finally get round to throwing all the bits back on the car, put wheels on and start the car. Starts fine. Washed it washed engine bay,,whilst car is running.
Jump in it next day, its dead.. Totally dead no dash display.. Nothing. Try putting battery charger in it for couple of hours, managed to get dash display but thats it, bearly enough power for anything else. Car will start off boost pack and everything is fine, left it running fir half an hour. Starts agaiin after leaving it 2hrs but next morning its dead again. No power whatso ever!
Any suggestions? Cheers
Instagram- airz182
Kam88
Re: 6 week old Battery dead
« Reply #1 on: March 20, 2015, 11:04:56 pm »
I would say potentially washing the engine bay buggered the battery if you used hose pipe or pressure washer that's the only thing I can think of get it changed under warranty
Offline OSB
  • -Given: 32
« Reply #2 on: March 21, 2015, 08:26:04 am »
Alternator damaged with the under bonnet washing? Car starts with Boost Pack, but wont generate enough to recharge the battery.
Check alternator output.
Offline Airz182
« Reply #3 on: March 21, 2015, 10:45:19 am »
Cheers lads going to check alternater when i finish work,
Instagram- airz182
Offline Airz182
« Reply #4 on: March 23, 2015, 10:31:45 pm »
Checked alternater, not sure whether it was correct way of doing it but i put multimeter on it red end on positive and earth touching the alternater casing.
Was getting a reading just under 14v
So guessing it was working. Used the car for around 15mins on Saturday. Started fine sunday, no problems started fine this morning, drove to work 5miles away from home. Finished work battery was dead again!
Instagram- airz182
Kam88
« Reply #5 on: March 23, 2015, 11:15:53 pm »
Could be blown cell get it replaced under warranty  :signLOL:
Offline wombar
« Reply #6 on: March 23, 2015, 11:26:12 pm »
Yeah, see if you can get it swapped  :wink: At least then you've ruled out the battery and can move onto something more expensive  :evilgrin:
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #7 on: March 24, 2015, 07:56:16 am »
Suggest you check for battery drain too
Offline Airz182
« Reply #8 on: March 24, 2015, 08:15:10 am »
How do you check for the battery drain? I gone out to it again this morning and its totally flat. Going to try exchange battery today. I just carnt work out why all of a sudden its just going flat for no reason.
Instagram- airz182
Offline wombar
« Reply #9 on: March 24, 2015, 08:32:40 am »
It's either a faulty battery, or something's draining it. Have you added anything new to the car recently (stereo etc)?
Offline Airz182
« Reply #10 on: March 24, 2015, 08:45:50 am »
No all ive done is painted a few bits on my car lol, i fitted a rcd510 last year but had the gateway coded and never had a issue.
Instagram- airz182
Offline wombar
« Reply #11 on: March 24, 2015, 08:51:33 am »
Well, next step is to get it swapped out and go from there I guess. Check the new battery voltage with everything off, then turn the engine on and see if the reading jumps up. If it doesn't, possibly a dodgy alternator.
Hopefully it's just a one off dodgy battery.
Offline xjay1337
  • -Receive: 377
« Reply #12 on: March 24, 2015, 10:02:54 am »
Not chance at all unless parts are already failing.
We wash loads of cars, we clean the whole bay, engine running, avoid spraying directly on the battery/alternator, will put a plastic bag over exposed batteries, nearly all cars are covered now.
Offline Airz182
« Reply #13 on: March 24, 2015, 10:47:52 am »
I mainly washed the sump and back of engine, battery had its cover on it. I did wash near alternater but i think its still charging
Instagram- airz182
Offline Airz182
« Reply #14 on: March 27, 2015, 05:57:25 pm »
Update, Changed the battery was fine for 2days. Jumped in it for work today... Flat!
Jumpstarted it went to work, flat again when i left work.
A lad doen the road seems to think the alternator could be discharging the battery?
Ive check the glovebox light, boot light.
Instagram- airz182
