Author Topic: Rns510  (Read 12655 times)
Offline liver
Re: Rns510
« Reply #15 on: December 01, 2009, 03:27:06 pm »
how much did cruise control set you back??
Offline Oli
  • -Given: 19
Re: Rns510
« Reply #16 on: December 01, 2009, 06:24:31 pm »
I think I paid about £40 for the stalk, and then one of my mechanics did the rest.
Update - I've ordered the fiscon and the glovebox mdi, so should be all in by Friday.
Offline Oli
  • -Given: 19
Re: Rns510
« Reply #17 on: December 01, 2009, 08:38:18 pm »
Another quick question.
My units part number is;
1TO 035 680 B
I presume this is a B version and will have the latest software?
Offline Oli
  • -Given: 19
Re: Rns510
« Reply #18 on: December 02, 2009, 06:36:54 pm »
Anyone, bueller, anyone?
Offline Lyons
  • -Given: 18
Re: Rns510
« Reply #19 on: December 02, 2009, 09:17:07 pm »
Lol, i see what you've done there.
Offline QD MBE
  • -Receive: 102
Re: Rns510
« Reply #20 on: December 02, 2009, 10:26:37 pm »
1TO 035 680 B
It is indeed a  version, as to what sw, you need to delve deep into the menu's on the set................
A geek will be along shortly to let you know how to do that!
Re: Rns510
« Reply #21 on: December 02, 2009, 10:32:13 pm »
I'm not falling for that one QD.  :P
To find the SW version open the car, turn the unit on and press and hold the setup button for quite a while, 60 secs I think.
Re: Rns510
« Reply #22 on: December 02, 2009, 10:34:46 pm »
60s? I press mine for something like 10-20 seconds.
Offline QD MBE
  • -Receive: 102
Re: Rns510
« Reply #23 on: December 02, 2009, 10:35:23 pm »
Ian -
Geek!!
 :grin: :grin: :grin:
Offline pazz
Re: Rns510
« Reply #24 on: December 02, 2009, 10:35:27 pm »
If that doesnt work, which if its 100% original it shouldnt (because its a version B). Then you'll need VAGCOM to change a setting to allow the setup menu to come up. I had to do this on mine. Simply just changing one of the bits from "0" to "1" or vice-versa etc on the nav controller.
EDIT: Just found it....
Quote
Using Vagcom/VCDS open Channel 37 – Navigation, go into adaption and change channel 50 to 1 (will be 0).
« Last Edit: December 02, 2009, 10:38:43 pm by pazz »
Re: Rns510
« Reply #25 on: December 02, 2009, 10:37:22 pm »
You are probably right Stealth as its been a while and I am on the latest 266x software.  :smiley:
@ Pazz that is only for 266x software and mine is factory fit.
Offline pazz
Re: Rns510
« Reply #26 on: December 02, 2009, 10:39:29 pm »
@ Hedge this is what I thought but I dont have 266x (which is the brand spanker am I right?)
I still had to change it.  :confused:
« Last Edit: December 02, 2009, 10:41:05 pm by pazz »
Re: Rns510
« Reply #27 on: December 02, 2009, 10:41:50 pm »
@ Hedge this is what I thought but I dont have 266x (the brand spanker am I right?)
Do you know which version you had? As far as I know you only had to change it for 266x. The previous version I had didn't need it.
@ QD, don't think I missed that.  :booty:
Offline pazz
Re: Rns510
« Reply #28 on: December 02, 2009, 10:42:20 pm »
@Hedge I'm pretty sure I'm on 900 or something, ancient I know!
On another note,
Has anyone managed to get their dealer to upgrade the firmware? Mine's going in next Monday so might see if they'll do it. I just dont wanna risk bricking it.
Re: Rns510
« Reply #29 on: December 02, 2009, 10:45:03 pm »
Is yours OEM or afters Pazz?
I took a chance as mine was factory fit and I was fine but I have heard of aftermarket ones that brick especially if they are a Heinz 57 special.
