Author Topic: Battery drain on replacement radio, how do i know if my car is affected?  (Read 936 times)
Offline Fands
Read up on here regarding changing the headset and the associated battery drain problems re canbus etc.
Also read it affects car built before 2008.
Mine is a registered 2008 but of course very probably manufactured before this so how can i tell if its affected?
Appreciate any wire words
Offline olsen-72
  • -Receive: 21
  • Redditch
Check part number on VCDS scan mate. But if you have already  drain problem after radio swap so i think your car is affected. But check it with vcds first.
I have some gateways if you will need one.
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
