June 21, 2026, 06:28:13 pm
All Things Mk5
Mk5 General Area
Replacing my DV
Topic: Replacing my DV (Read 1839 times)
jacobrownoly
Always Involved
-Given: 23
-Receive: 8
Replacing my DV
March 29, 2015, 07:13:38 pm »
Hey, just looking for some help regarding the Diverter Valve.
I have had the car revo'ed and I have heard that the DV on the MK5 gti is weak against the map.
Looking at buying this, I believe the "D" is the one to go for:
http://www.ebay.co.uk/itm/F-A4-TT-A3-A5-VW-Beetle-Golf-Jetta-Passat-GTI-Diverter-Turbo-Cut-off-Valve-New-/201278413142?_trksid=p2054897.l4275
For £40 its probably worth just replacing my stock one.
Many thanks
GrayMK5GTI
Global Moderator
Just look at my post count
-Given: 125
-Receive: 248
Re: Replacing my DV
Reply #1 on:
March 29, 2015, 08:00:47 pm »
Try Awesome GTI or even your local VW dealer. The one in the link is located in China, may take a while to arrive
Daled0111
Always Involved
-Given: 26
-Receive: 4
My Ride:
Re: Replacing my DV
Reply #2 on:
March 29, 2015, 08:04:12 pm »
I put a forge dv valve spacer (blow off valve) and it had a boost leak,
I then took the stock dv off to find the rubber diaphragm has split (is a common problem with the original valves) so I ordered a new on from VW themselves and it looks the same as that one you are looking at on eBay, it's a redesigned one so they don't split as easy and that cost me 40 pound so if I was you I would buy one from dealer for the same price or you can get a kit to repair yours to make it withstand the increase In boost
http://m.ebay.co.uk/itm/271807912516?nav=SEARCH
Hope this helps it's my first reply on here
Matthewsimone
Won't Shut up.
-Given: 52
-Receive: 39
Re: Replacing my DV
Reply #3 on:
March 29, 2015, 08:04:32 pm »
Revision G is the one you want mate
D is prone to seeping boost leak
Just call local vw dealership I bought one recently from there £42
jacobrownoly
Always Involved
-Given: 23
-Receive: 8
Re: Replacing my DV
Reply #4 on:
March 29, 2015, 11:52:16 pm »
Thanks guys! I have heard that the D one is the one to go for tho?
samiul11
Always Involved
-Given: 9
-Receive: 15
Re: Replacing my DV
Reply #5 on:
March 30, 2015, 12:23:23 am »
I recently put a rev G in but after 3 weeks the car feels weak on boost again
so i think it might have teared already
All Things Mk5
Mk5 General Area
Replacing my DV
