Author Topic: Mk 6 engine cover on a mk 5 ?  (Read 1139 times)
Offline Steve in crete
« on: April 16, 2015, 04:29:58 pm »
Hi, I have inherited a massive cold air inlet system on my car which stops the fitting, I assume, cos I don't have one, of an engine cover ?  I have looked on eBay and the mk 5 is a big all singing dancing item which is why it won't fit, but the mk 6 appears to be much smaller and compact ?
Even if it's not a straightforward fit I would have to modify less than the mk 5 version, the engines are more or less the same are they not so will it fit, I quite like the idea of having the engine bay finished off a little better than it is currently ?
Your help as usual would be much apreciated.     Steve
Kam88
Re: Mk 6 engine cover on a mk 5 ?
« Reply #1 on: April 16, 2015, 04:34:21 pm »
10 minutes to cut down mk5 engine cover problem solved i know engine cover off tts or ttrs will work
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #2 on: April 16, 2015, 10:24:11 pm »
Audi TTS engine cover fits with an aftermarket intake kit
http://shop.lvsracing.co.uk/audi-tts-engine-cover-2696-p.asp
