Author Topic: Traction Issues Revo Stage 1  (Read 7607 times)
Offline Rob GTI
« on: December 08, 2009, 02:43:51 pm »
Had the car REVOd last week with settings B7, F7, T5 and in this wet weather not getting any joy getting traction in lower gears over 3k revs. The tyres are Mich Pilot Sp 2 with about 5mm tread all round and I've been feeding the power in progressively. I had a Leon FR Stage 2 Leon developing the same torque figures at 3k revs before this and while it did wheelspin it was a lot more controllable, although not perfect.
Now I've got the select plus switch plus switch on order (freebie through their Dec promo) so was thinking of changing the settings to something more conservative for the wetter / colder months, any suggestions on settings for this?
One more question whats the traction like in the dry?
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
  • -Receive: 453
Re: Traction Issues Revo Stage 1
« Reply #1 on: December 08, 2009, 02:47:39 pm »
Do you have an uprated HPFP?
If not, I suggest you turn yout fuelling to 9 as recommended by revo.
Offline SteveS
« Reply #2 on: December 08, 2009, 02:56:41 pm »
mine is b8 f9 t5, turn the boost down if you have a heavy foot :p
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline GTIjames
« Reply #3 on: December 08, 2009, 02:59:21 pm »
i have just recently put michelin ps2's on all conrners and have noticed the traction in the current wet conditions is not quite as good as my previous tyres conti sport contact 3's. i have been getting wheel spin in 4th lately...
in the dry the ps2's are awesome alot better than conti's
the ps2 is meant to be a summer tyre though...
reducing the boost will help but won't be as much fun  :driver:
Offline Rob GTI
« Reply #4 on: December 08, 2009, 03:05:22 pm »
No pump all standard apart from map. Don't really know why the setting were put are they were it was all done following logging by the tuner.
Offline Rob GTI
« Reply #5 on: December 08, 2009, 03:06:52 pm »
I'll try turning the boost down one setting at a time see where that gets me.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #6 on: December 08, 2009, 03:23:17 pm »
I would also be getting your tracking checked and having a play with the tyre pressures  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline Rob GTI
« Reply #7 on: December 08, 2009, 03:37:12 pm »
Less tyre pressue, better traction???
« Reply #8 on: December 08, 2009, 03:59:50 pm »
....Possibly but mind how you go - Less pressure can result in uneven tyre wear.
There are so many factors : -
- Tyre tread depth and condition.
- Tyre type re rubber.
- Tyre pressure.
- Road surface.
- Suspension: many factors within that.
- Your right foot.
« Last Edit: December 08, 2009, 04:03:28 pm by RedRobin »
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #9 on: December 08, 2009, 04:04:50 pm »
not necessarily, I have found the PS2's prefer to have higher pressures (counterintuitive but seems to work)  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline wigit
  • -Given: 129
  • -Receive: 42
« Reply #10 on: December 08, 2009, 04:06:11 pm »
mrs wigit is learning to moderate the ferocity she applies pressure with her size 4 during these wet winter months as unfortuantely she tries to drive it in the manner of her old 1.8 astra
Offline animal
  • .:R32
« Reply #11 on: December 08, 2009, 04:06:48 pm »
Definitely get all your geometry checked. How does the car handle - do it feel stable once moving and cornering, or does it feel twitchy?
Also, get the bushes, engine mounts and suspension checked out, if something is failing or has failed, excessive movement might be unloading the front wheels too much when you floor it.
Also bare in mind that most cars are going to struggle this time of year regardless of power. You might just need to modulate the power a bit better.
Offline animal
  • .:R32
« Reply #12 on: December 08, 2009, 04:08:30 pm »
Or try taking off in second...  :happy2:
Offline Rob GTI
« Reply #13 on: December 08, 2009, 04:17:07 pm »
Will get geometry checked but have had no issues with handling, steering before. Will be looking to get the dog bone mount upgrade done shortly as I had it on the Leon (powerflex) and was great at reducing wheel hop.
Offline Rob GTI
« Reply #14 on: December 08, 2009, 04:18:12 pm »
I don't do hard starts at all in first, the problems I get are predominately in 2nd anyway!
