Author Topic: Sloppy gears?  (Read 6050 times)
Offline PT82
  • -Given: 19
Sloppy gears?
« on: May 31, 2015, 01:39:58 pm »
Hi guys
Can people please review my video below and let me know if this is normal. I have a feeling bushes are worn somewhere. If so can you let me know the part numbers or post a link to solve this. I realise a quickshift will help also.
« Last Edit: June 05, 2015, 07:55:55 pm by PT82 »
Offline Matthewsimone
  • -Receive: 39
Re: Sloppy gears?
« Reply #1 on: May 31, 2015, 01:51:54 pm »
Mine are 110% not like that mate
Im 57 plate on 72,000 miles and gear change is tighty tight in mine
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: Sloppy gears?
« Reply #2 on: May 31, 2015, 02:20:41 pm »
Yeah, mine's like that, I changed the Gearlinkage bushes to no effect.. I think it's something snapped around the gearstick, I'm almost sure I read someone had changed a plastic bit out and it fixed the issue, but I never got around to doing it - I'll have a look for the post, unless someone else can find it..?
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Offline PT82
  • -Given: 19
Re: Sloppy gears?
« Reply #4 on: May 31, 2015, 02:22:49 pm »
I new something wasn't right. I have been looking through the the forum at the quickshift said and bushes to buy and it's a bit of a minefield to be honest. I'm a bit stumped.
http://www.awesomegti.com/car/vw/golfmk5?subpart=QuickShifts
Offline PT82
  • -Given: 19
Re: Sloppy gears?
« Reply #5 on: May 31, 2015, 02:25:20 pm »
Offline Panthera
Re: Sloppy gears?
« Reply #6 on: May 31, 2015, 02:26:14 pm »
That is exactly the same issue I had with my 57 plate 6sp manual, but when the engine was running the box would block 1st gear and I would have to re try, sometimes going into second then in to first. On mine is was end float issue in the gear box.   The specialist i used took the box off, and took it to a gearbox specialist who shimmed for end-float issue, cleaned and polished selector forks. They replaced the gearbox selector bracket, shoe and clip along with clutch and flywheel. See my other thread...   http://www.mk5golfgti.co.uk/forum/index.php/topic,97806.msg966230.html#msg966230
The other option could be that the garage did think was to rebuild the bear linkage under the gear leaver.   I would suggest take it to a specialist you trust and know their work before trying to self diagnose.
« Last Edit: May 31, 2015, 02:31:29 pm by Panthera »
2007 Blue Graphite Golf GTi
Offline PT82
  • -Given: 19
Re: Sloppy gears?
« Reply #7 on: June 05, 2015, 07:33:33 pm »
So I had a punt on the recommended part. I thought it was worth a shot for only £2.85.
I opened the gearstick panel and this is how everything looks
I don't think the part is the problem. From what I can see it's the white plastic part to the left being to loose in the metal bracket, as seen in the video below. I am happy to be told wrong. What you guys think?
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
Re: Sloppy gears?
« Reply #8 on: June 06, 2015, 11:27:52 am »
Your videos are now private for some reason dude
Offline PT82
  • -Given: 19
Re: Sloppy gears?
« Reply #9 on: June 06, 2015, 01:06:54 pm »
Cheers buddy, now amended  :happy2:
Offline PT82
  • -Given: 19
Re: Sloppy gears?
« Reply #10 on: June 07, 2015, 12:19:44 pm »
Anyone?  :smiley:
Offline PT82
  • -Given: 19
Re: Sloppy gears?
« Reply #11 on: June 09, 2015, 09:37:38 pm »
 :sad:
