Author Topic: Intake Manifold Flap Motor v157  (Read 13010 times)
Offline SeyiiOluwa
« on: June 07, 2015, 11:17:00 am »
Hey guys, I'm kind of new to this, and  I've searched a few places but haven't been able to find a Mk5 forum with knowledgeable people like on here.
So I bought my Mk5 (TDi please don't shoot me :innocent:) in October and the emissions light has been on ever since. Whenever I plug it in it says
P3101 : motor for intake flap
V157 : open or short to ground
Been to VW and they quoted just under £700 to fix, another local garage near uni said they'd do the same job for just under £400. My local mechanic had a look and said that my throttle body is new so shouldn't need replacing (i'm guessing this fault has something to do with the throttle body). I've booked an appointment to see him so he can clean my intake manifold (and delete my EGR) as he claims this will clear the fault.
Since i've had the car I haven't had any power issues (but that may be because I don't know what the car is supposed to feel like). Am I making the right decision by going to clean the manifold or will that be another waste of time (and money). If I need to spend the extra money then I'd rather not go get the manifold clean.
Sorry if its already been covered in a previous topic
Offline Vagperformance
Re: Intake Manifold Flap Motor v157
« Reply #1 on: June 08, 2015, 09:21:14 pm »
There's a fuse that pops when that unit goes faulty, it's in the engine bay on the n/s of the vehicle
Offline SeyiiOluwa
« Reply #2 on: June 08, 2015, 09:32:45 pm »
Do you know which one it is? I can check my handbook. Been to the garage again today and they reconfirmed that the throttle body was fine. Hopefully you're right
« Reply #3 on: June 08, 2015, 09:39:43 pm »
I honestly can't remember, got a feeling it's a 10amp fuse. If you have the ignition off just pull the fuses individually, you'll see if it's blown or not.
Offline AIR_CHILLED
« Reply #4 on: June 22, 2015, 08:57:29 pm »
Hello,
I have recently changed this  flap control valve on my diesel ('54 A3 2.0TDI Sport)
The throttle body / intake flap is there to control emissions when engine is warm and at idle e.g sitting in traffic. It's main function though is a anti-shudder valve and is used to stop airflow when engine is switched off to promote a smoother stop.
The two main causes why it is blowing the fuse is if the plastic gears have stripped or the electronics fail. (Mine filled with oil through the worn sealing bush on the spindle)
I bought the valve from Eurocarparts for £100 with promotional discount and the seals from Audi.
While I was at it I cleaned the EGR valve, fitted a EGR OEM restrictor gasket from an Audi 80 and changed the intercooler seals.
Quoted £700 is a joke and £400 pounds is also laughable. The OEM part that Audi sell for £250+ Eurocarparts sell (Pitsburgh or something)
Easy Diy If you handy with the spanners.
Hope this helps.
Cheers,
Mike.
« Last Edit: June 22, 2015, 08:59:23 pm by AIR_CHILLED »
Offline SeyiiOluwa
« Reply #5 on: June 26, 2015, 02:47:56 pm »
So I've finally got the light sorted. Went to the mechanic and they looked under the bonnet and saw that all the suspected parts had already been replaced
After some tests we discovered that it was faulty wiring from a previous job (before I bought the car). A few hours and £200 later the car was fixed and I was on my way back to London to finally enjoy a fully working vehicle (throttle response was night and day)
My joy was short lived as the following day the light came back. To cut a long story short I ended up driving 65 miles back to the mechanics (angry as ever) expecting them to give me a free fix only to discover that my EGR was receiving intermittent signal.
Apparently this fault wouldn't have been detectable until the intake manifold issue was sorted meaning that I had to replace the EGR at a cost of £150
£350 and 260 miles later my car is fixed. No lights on the dash but it drives the same as it did when my intake manifold wasn't working.
I'm now wondering why I had a nice throttle response for a day and now that everything is done the car isn't driving much better. I thought clearing the light would make the car feel better. Maybe I need to do some more repairs or wait till I service it (due in 2800 miles)
« Last Edit: June 26, 2015, 03:33:34 pm by SeyiiOluwa »
Offline SeyiiOluwa
« Reply #6 on: June 26, 2015, 02:48:34 pm »
Big thanks to @air_chilled and @vagperformance for your input. Really appreciated
« Reply #7 on: June 26, 2015, 03:05:33 pm »
Did it sort it?
Offline AIR_CHILLED
« Reply #8 on: June 26, 2015, 03:12:56 pm »
Yes I'm interested to know if you sorted it?
My poor throttle response at low speeds is down to the intercooler hoses / pipes leaking which I'm trying to sort out now.
It's frustrating when one fault /area is masking the other and effectively you have to pay out twice! £££ :(
Offline SeyiiOluwa
« Reply #9 on: June 26, 2015, 03:22:01 pm »
@vagperformance @air_chilled
The car is now sorted but it doesn't drive as well as I believe it can. I feel like I wasted money removing the warning light and replacing the EGR. When I get paid I'm gonna get the car checked out again, maybe there's something else that needs to be changed/fixed :(
I've been stalling the engine a lot more for some reason. Because I drive a dirty diesel I normally take off with my torque and add the extra boost if needed. Since fixing the car the torque (or something) has dropped as my driving style now makes me stall
« Last Edit: June 26, 2015, 03:32:05 pm by SeyiiOluwa »
Offline yarickpi
« Reply #10 on: July 13, 2015, 04:44:59 pm »
did I misread the question? you seemed to be wondering if when installing your new intake manifold if you should do VTCS delete as well, and I responded by saying that the VTCS is located in the stock manifold so by switching manifolds you will already be removing VTCS.
Если дела идут плохо не ходи с ними.
Offline NotNormal
« Reply #11 on: July 13, 2015, 06:58:44 pm »
@SeyiiOluwa they really need to be adapted via VCDS to make the most out of the new part.
If you're local to Lincoln PM me and i can sort it for you. Otherwise, look on the VCDS register on here and PM a local person
Hope it helps
Tom
Don't judge me by your ability !
__________________________________
Current daily crapper - Audi A6 Avant 3.0tdi SLine Quattro
Previous favourite rides :
BMW E92 335d M/Sport (351/520)
BMW  E92 335d SE (339/500)
Golf MK5 GT170 Diesel Sport (220/330)
Audi S4 (B6) - Noggy blue (366bhp)
Evo VI (6 ;) ) RSII - Scotia White (420bhp)
Astravan Sportive 1.9 CDTi - 190bhp
Astra GTE (MK2) Turbo (
Offline SeyiiOluwa
« Reply #12 on: July 18, 2015, 03:14:05 am »
I was wondering why the car didn't improve in performance after repairing the manifold wiring and the EGR
Offline SeyiiOluwa
« Reply #13 on: July 18, 2015, 03:14:38 am »
Hope it helps
Tom
Thanks for the help, is this the same even for an EGR replacement ??
Offline NotNormal
« Reply #14 on: July 18, 2015, 07:24:03 am »
Hope it helps
Tom
No, erg replacement is a straight forward swap - no adaption required
