Author Topic: *pic request* eibach sportline's fitted  (Read 33213 times)
Offline broke.
« on: December 18, 2008, 11:48:49 pm »
I have just acquired a mk5 golf gti (05) i am looking to fit eibach sportlines. the car is currently on 17" monza's but looking to fit 18's at the same time i fit the sportlines.
are there any pics of mk5 gti's with the sportlines fitted? 17's or 18's will be fine.
Thanks in advance  :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
Re: *pic request* eibach sportline's fitted
« Reply #1 on: December 19, 2008, 07:50:10 am »
I believe the Rim King's car is fitted with the said springs: -
:drool: :drool: :drool:
« Reply #2 on: December 19, 2008, 10:01:27 am »
and so is Robmkv car
http://www.mk5golfgti.co.uk/forum/index.php?topic=257.0
and mine will be in a few weeks  :wink:
Offline broke.
« Reply #3 on: December 19, 2008, 10:39:23 am »
thanks for the responses guys :happy2:
would 17's be too low do we think? anybody fitted the sportline's with 17's?
Mat, have i seen your car around leeds?
« Reply #4 on: December 19, 2008, 10:41:07 am »
yes you will have i am over leeds all the time :smiley: you from leeds?
« Last Edit: December 19, 2008, 10:51:04 am by MAT ED30 »
Offline broke.
« Reply #5 on: December 19, 2008, 11:15:09 am »
wakefield matey :confused:
i'm thinking about going for less of a drop, maybe 15mm and keeping with 17's just changing the wheel. anybody recommend an springs that will lower a genuine 15-20mm? i know the pro kit did but i believe thats been stopped in production now.
KW  -20mm  £122.34
Eibach Pro  -10/15mm  £136.85
Weitech  -20mm  £112.55
leaning towards the KW kit at the moment but not ordering until early jan so gunna have a good think.
Tom
« Last Edit: December 19, 2008, 11:30:34 am by broke. »
« Reply #6 on: December 19, 2008, 11:46:25 am »
there has been a price increase from eibach pro but try these guys as they may have them still in stock and they are the cheapest about at the mo for springs  :happy2:
http://www.motorsportworld.co.uk/
Offline broke.
« Reply #7 on: December 19, 2008, 12:06:40 pm »
thanks mate, appreciate that. just on the link now...
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #8 on: February 15, 2009, 01:20:01 pm »
Folks, need some advice...
Fitted Eibach Sportline springs on my Golf GTi (DSG). Car was only a month old when the new ones were installed. Ever since then I get an occasional rubbing/thud noise when going round corners or bumpy roads.
The noise appears to emanate only from the driver side (UK right hand drive car).
Contacted Eibach and they have said they have never experienced this problem. After much discussion, and the fact the car was literally brand new - they offered to provide a replacement set, fitted free of charge.
After going through the hassle of getting a new set fitted the problem is still there
What could it be, and why is it just the one side? Is this to be expected with the Eibach Sportline kit? Has anyone else had similar experiences with the sportline kit? Any suggestions what else I could check?
Before anyone says, I only weigh 76Kg.
I should mention...the noise only started after I had the Eibach springs installed. I have thought about taking the car to my local dealership - but I have had a far from acceptable experience from them.
I expect them to say that the problem is as a result of having after market installed springs - even though the Eibach ones are better. They will probably try to squirm out of any potential work/warranty claim...
The occasional knock/scrub noise definitely emanates from the front driver side wheel...it happens when I turn to the left firmly or go over a speed hump at moderate speeds - basically stuff which normally did not cause a problem before.
I'd be interested from anyone with Eibach sportline springs - and know if they have had similar problems - or what it might be.
Thanks,
Mo
  • -Receive: 453
« Reply #9 on: February 15, 2009, 01:54:58 pm »
mojo, you should try removing the arch screw on the driver's side and tucking the plastic liner behind the screw hole.
Offline LaserBlue
« Reply #10 on: February 15, 2009, 02:01:26 pm »
i thought that simply just upgrading the springs without shox was a no no?
something of an impression i got from reading through threads  :confused:
  • -Receive: 453
« Reply #11 on: February 15, 2009, 02:06:09 pm »
You can do it safely with springs that don't lower the car much like the eibach pro's but the shocks may not last as long.
Offline gazbutS3
« Reply #12 on: February 15, 2009, 02:54:58 pm »
as bacillus says, remove the liner screw and tuck the liner up behind the tab to hold it in place, that should fix it :happy2:
  • MUBster DUBster
« Reply #13 on: February 15, 2009, 04:10:37 pm »
Thanks guys...
Not sure what you mean by the liner screw and where the tab is.   Can some one please elaborate?
I've had a look and can see there is a single screw which holds the plastic housing in the wheel arch.
P.S.  With the screw removed won't that leave the bits to move around at high speed?
Regards,
Mo
« Reply #14 on: February 15, 2009, 04:14:07 pm »
Glad to see you made it here, Mo  :happy2:
Sooner or later peeps here will get you helped.
