Author Topic: Golf R32/R/S3 Rear Brake Upgrades?  (Read 16275 times)
Offline teo_parvu
  • -Given: 30
  • -Receive: 57
Re: Golf R32/R/S3 Rear Brake Upgrades?
« Reply #15 on: July 09, 2015, 07:37:54 pm »
It will be ok don't worry, DS2500 are not that aggressive 0,42 friction coef compared to EBC Red Stuff 0,5.  :happy2:
You'll also get better cooling from the vented disks.
Can't wait for your first impressions. They will need 200/300 km to bed in properly.  :driver:
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #16 on: July 09, 2015, 07:51:10 pm »
Nice. I can't wait to have all done and the car back in my hands. :driver:
I've ordered the R32 dust shields too (5N0615611E and 5N0615612E), to have a complete OEM look. :smiley:
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
« Reply #17 on: July 09, 2015, 08:42:33 pm »
Quote from: Shoduchi
Aren't they for the 4motion hubs only?
Offline teo_parvu
  • -Given: 30
  • -Receive: 57
« Reply #18 on: July 09, 2015, 08:59:07 pm »
No, they will fit fine on normal hubs. ;)
They'll fit perfect on yours too.
« Last Edit: July 09, 2015, 09:01:28 pm by teo_parvu »
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #19 on: July 09, 2015, 09:02:05 pm »
AFAIK only one bolt might not fit properly, so it may be required to drill an hole for it to fit perfectly. :happy2:
Offline th3_f15t
  • -Receive: 183
« Reply #20 on: July 09, 2015, 09:40:33 pm »
I might go down this route you know, looking at costs and it's crazy not to! So far I've found these on eBay...
Fronts:
http://www.ebay.co.uk/itm/281729609971?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Rears:
http://www.ebay.co.uk/itm/231610832790?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Need to work out discs, pads, adaptors and lines now! But so far calipers and refurbs looks to be less than £1000, my mission will to be to get both front and rear set ups for less than the cost of VW Racing front 6 piston brakes.
Saying that:
http://www.awesomegti.com/car/vw/golfmk6/ecs-stage-5-big-brake-kit-drilled-grooved-358x32mm
Could be a winner, just get the rears at a later date to match the ECS Tuning kit.
If anyone's got a how-to guide for doing this kit, PLEASE let me have it as I'll need as much info as possible. May even fit these myself to save more money, rude not to now I have a full work shop at my disposal!
« Last Edit: July 09, 2015, 09:48:01 pm by th3_f15t »
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #21 on: July 09, 2015, 10:49:38 pm »
Front setup DIY: http://forums.vwvortex.com/showthread.php?5830375-Brembo-18Z-6-piston-brake-upgrade.-DIY-BBK-write-up.-Big-brakes-for-under-a-grand.
Disc brakes:
-ML55 or GL450 350 mm
Pads:
Ferodo DS2500 (330 mm discs) (190,1x99x16,8) FCP1625H
Pad wear sensor wires: http://www.ebay.co.uk/itm/381287223597
Braided brake lines: http://www.ebay.co.uk/itm/111046291292
Aluminium discs centring rings: http://www.ebay.co.uk/itm/111392994828
Calipers adaptors: http://www.ebay.co.uk/itm/111067552499
It's better to get the pads for the Brembo 17Z calipers since they match perfectly with the 350 mm ML discs. I got the EBC Redstuff for the 17Z (DP31521C).
You can get the calipers, adaptors and brake lines from this shop: http://www.ebay.co.uk/itm/151515479484
Addiction Motorsport has all that you need but not all items have the best price available. The store also recommends to get the smaller pads (DS2500 FCP1625H) for the 18Z: http://www.ebay.co.uk/itm/111049676173. :wink:
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #22 on: July 09, 2015, 10:56:12 pm »
Other bits that may be needed to refurbish the calipers:
Caliper boots and seals (kit incl. 2x30mm, 2x34mm & 2x38mm boots and seals): 2x 143.35037
Pins and retention clips: 95535195900
Crossover lines: 2x 95535196110
Front bleeder valves with boots: 2x 93035191900
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=26rpoojnk1brcvovnlbd5s298o&/topic,90967.msg917089.html#msg917089
« Reply #23 on: July 09, 2015, 11:00:03 pm »
What about the HB caliper? I know it does FA but it looks  :drool:
05 | Tornado Red | DSG
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #24 on: July 09, 2015, 11:10:02 pm »
I didn't get the HB nor the FA... Sorry dazza. :confused:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #25 on: July 09, 2015, 11:21:49 pm »
Handbrake caliper? I posted about them a while back as someone on vortex had a group buy on the brackets think they were using Cayenne calipers and a Handbrake caliper from an R8 or jag.
FA = f*ck All.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #26 on: July 09, 2015, 11:25:55 pm »
FA = f*ck All.
Right! :happy2:
Yeah, the HB caliper should be from an R8. Not sure if the bracket wasn't a custom order from a latte... :confused:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Offline th3_f15t
  • -Receive: 183
« Reply #28 on: July 10, 2015, 08:22:30 am »
@dazza - http://www.creationsmotorsport.com/product-detail.php?pid=667
Found this while on a massive Google search last night. I e-mailed them to find out about whether you can fit a Brembo HB rather than use the stock OE caliper (as mentioned in the description). Brembo HB:
http://www.brembo.com/en/Van/Original-Equipment/Products/Pages/Freno-di-stazionamento.aspx
And for info, I've used PW Motorsport before, they're top guys! Trouble is, I'd like my calipers in matching colours and both in blue so I'll probably buy some calipers that need a refurb and get them done myself.
So much for the Golf R staying stock!
Offline th3_f15t
  • -Receive: 183
« Reply #29 on: July 10, 2015, 09:15:14 pm »
Also, if anyone can find where to get parking brakes from, that'd be great. So far I can only find a set of Aston Martin ones in the USA at $600 before shipping!
