September 04, 2026, 01:58:46 pm
All Things Mk5
Mk5 General Area
Radiator fan pulsating
Topic: Radiator fan pulsating (Read 2038 times)
Daled0111
Always Involved
-Given: 26
-Receive: 4
My Ride:
July 11, 2015, 06:12:16 pm »
The fan is pulsating when I lock my car anybody got any idears
doylebros
Just look at my post count
-Given: 44
-Receive: 310
Re: Radiator fan pulsating
Reply #1 on:
July 11, 2015, 07:00:18 pm »
Get it scanned with VCDS
http://www.mk5golfgti.co.uk/forum/index.php/topic,88875.0.html
and see what it shows as I've had a few strange things happen when this item fails
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=1&grf=012130474&bf=12130&hgug=121&ug=21&parent_id=2337093&detail_id=2337133
Daled0111
Always Involved
-Given: 26
-Receive: 4
My Ride:
Reply #2 on:
July 12, 2015, 10:41:41 am »
Have scanned it at work with our snap on top of the range scanner but there are no codes stored
doylebros
-Given: 44
-Receive: 310
Reply #3 on:
July 12, 2015, 10:57:43 am »
With the engine running and the aircon on low are both fans running?
Daled0111
Always Involved
-Given: 26
-Receive: 4
My Ride:
Reply #4 on:
July 12, 2015, 03:28:54 pm »
yh think so
Daled0111
Always Involved
-Given: 26
-Receive: 4
My Ride:
Reply #5 on:
July 12, 2015, 09:27:03 pm »
Quote from: doylebros on July 12, 2015, 10:57:43 am
Yes both fans kick in when turn aircon on and then they go off when I turn it off
doylebros
-Given: 44
-Receive: 310
Reply #6 on:
July 12, 2015, 09:34:29 pm »
Assuming there's plenty coolant and your thermostat and inline stats are ok I would look at the auxiliary coolant pump
http://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/33-WATER-Electric_Coolant_Pump_Replacement/33-WATER-Electric_Coolant_Pump_Replacement.htm
With VCDS you can run and test the pump in output test etc and check system values for temperatures.
Daled0111
Always Involved
-Given: 26
-Receive: 4
My Ride:
Reply #7 on:
July 12, 2015, 11:48:15 pm »
Just done a battery test with a computer from work and it says bad and replace
Would this have anything to do with it
All Things Mk5
Mk5 General Area
