Author Topic: rear suspension springs removal  (Read 3056 times)
Offline jimmy-s3
« on: December 26, 2009, 04:32:01 pm »
Im changing my rear suspension  and im looking for advice on removing the rear springs? The shocks were easy but not 100% sure on the technique on removing these??
Thanks in advance!
Offline Pesky jones
Re: rear suspension springs removal
« Reply #1 on: February 21, 2016, 08:02:33 pm »
Sorry for bringing this up but wondering how people have done this, my haynes manual tell me to put spring compressor on and just compress till it comes out, but my compressors are supposed to be used in pairs opposite to each other and mine wont fit both on.
Pelican guide says disconnect one bolt and lower the.wishbone with a jack. However, the bolt seems to half.way between a 17mm and an 18?!
« Reply #2 on: February 21, 2016, 08:11:32 pm »
I take the bolt out and lower the arm down
Offline Pesky jones
« Reply #3 on: February 21, 2016, 08:25:10 pm »
Yeah seems simpler, do you know what size the bolt head and nut are?
« Reply #4 on: February 21, 2016, 08:32:03 pm »
Think they are 17mm but could be wrong
Offline SI-R32
  • -Receive: 126
« Reply #5 on: February 22, 2016, 12:05:38 am »
just to add a slight bit to this the spring may still be under a bit of tension, so please don't just take the bolt out, use another jack under the arm the spring sits in to compress the spring ever so slightly to make the bolt removal easy then lower the jack off then the spring will easily come out safely.
Offline Pesky jones
« Reply #6 on: February 22, 2016, 12:23:36 am »
Thanks si, I had intended to do so, just forgot to mention that in the process.
