Author Topic: Kufatec Fiscon BT and MK6 MFSW  (Read 3159 times)
Offline bluo
« on: November 02, 2015, 08:24:29 am »
Wonder if you chaps could help...?
I've got a mk5 GTi with a mk6 MFSW, rns510, and a fiscon plus installed.
When I make calls via BT and use the steering wheel controls to terminate that call I can't make any further calls unless I disconect the phone and reconnect it. It's almost like the fiscon stays in terminate mode and does not attempt to connect a new call.
On the other hand, if I make calls using the head unit, then it works like it should do and I can make multiple calls no problem. I can control the volume via the steering wheel - so long as I don't hang up using the steering wheel there is no problem...
To me it sounds like a steering wheel coding issue but the steering wheel works like it should do I'm baffled!!
Anyone had this problem before or know what it may be? Kufatec have been useless in helping out...
Offline bluo
Re: Kufatec Fiscon BT and MK6 MFSW
« Reply #1 on: November 05, 2015, 08:55:11 am »
No one experienced this before?
Offline xjay1337
  • -Receive: 377
« Reply #2 on: November 05, 2015, 09:05:03 am »
Worked fine for me with my rocco (mk6 interior/wheel). andriod phone and rcd510.
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
« Reply #3 on: November 05, 2015, 10:39:32 pm »
Mine does this sometimes too..
I've had to take the centre console out to disconnect completely and then reassemble and it works fine.. for so long and then I can make a call again and it rings and works fine etc but not long down the line of it working again it stops working properly..
It makes a call but the sound of the phone ringing or the person on the other end talking does not come through the speaker therefore they can hear me but i can;t hear them as their voice is not coming through the speakers..
« Last Edit: November 07, 2015, 12:32:54 am by CarlW »
Offline bluo
« Reply #4 on: November 05, 2015, 11:38:24 pm »
Manual or dsg?
MFSW?
Are you able to provide coding that I can reference?
Offline CarlW
« Reply #5 on: November 07, 2015, 12:33:36 am »
Edited my original post above to make more sense.. May be we are having the same problem or similar?
Offline xjay1337
  • -Receive: 377
« Reply #6 on: November 07, 2015, 01:01:49 am »
Manual or dsg?
MFSW?
Manual and yes.
What coding bud? No coding required :-)
My car has oem bluetooth which was disabled and fiscon installed.
I use my kenwood head unit one now anyway
Offline bluo
« Reply #7 on: November 07, 2015, 07:59:55 am »
Manual or dsg?
MFSW?
Manual and yes.
Coding for the steering wheel- I'm starting to think the coding is messing with the fiscon as it only messed around if I disconnect a call using the MFSW. If I use the head unit there's no issues!
Offline xjay1337
  • -Receive: 377
« Reply #8 on: November 07, 2015, 03:21:04 pm »
Next time I take laptop to the car I will check
Offline bluo
« Reply #9 on: November 07, 2015, 05:15:20 pm »
Thanks pal.
