Author Topic: ko4 turbo oil leak  (Read 5527 times)
Offline guyrocks
  • -Given: 17
ko4 turbo oil leak
« on: November 03, 2015, 11:14:08 pm »
As above could anyone help or know where this will be coming from
Offline guyrocks
  • -Given: 17
Re: ko4 turbo oil leak
« Reply #1 on: November 04, 2015, 12:06:00 pm »
Anyone know of how much a turbo rebuild normally costs........ just a rough idea
Offline DANBOY66
  • -Given: 41
« Reply #2 on: November 04, 2015, 12:08:49 pm »
beach buggy anti surge turbos are £400 rebuilt :wink:
Dan..
Offline jhook661
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98678.0.html
« Reply #3 on: November 04, 2015, 07:05:55 pm »
Might be from rocker cover gasket or rear pcv valve have you changed your front pcv recently ?
Modded Golf gti CDL engine TTE420 turbo
Rtech 440bhp 429ftlb
Offline guyrocks
  • -Given: 17
« Reply #4 on: November 04, 2015, 08:24:52 pm »
No m8 I've not I was told by the garage it was fine when I was asking about it...... the valve that is not the oil
Offline jhook661
  • -Receive: 20
« Reply #5 on: November 05, 2015, 04:27:41 pm »
May worth sticking your hand down the back of the engine and feel just under the rear pcv valve if it's leaking out of there mine was
Offline guyrocks
  • -Given: 17
« Reply #6 on: November 05, 2015, 08:17:54 pm »
Will do cheers m8 fid you change your own
Offline jhook661
  • -Receive: 20
« Reply #7 on: November 05, 2015, 09:13:07 pm »
Yeah I changed mine myself simple job if your changing yours make sure you get one with the check valve in it I'm guessing you've got a edition 30 ?
Offline guyrocks
  • -Given: 17
« Reply #8 on: November 05, 2015, 11:46:32 pm »
Yer that's right m8 it's a fart on or easy job
