Author Topic: Coil pack connector clips  (Read 3565 times)
Offline Bo!
« on: January 04, 2016, 07:51:52 pm »
Hi
A couple clips that connect to the coil packs are broken . I have did a search and it shows this is a common issue.
The engine cover is back on so its not visible but do I need to get this sorted .?
If it does is appreciate part no's for the clips .
And also what a vag specialist would likely charge for doing this .
Cheers .
Offline doylebros
  • -Receive: 310
Re: Coil pack connector clips
« Reply #1 on: January 04, 2016, 08:33:09 pm »
They sell a repair kit http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=9&grf=097111420&bf=97111&hgug=971&ug=71&parent_id=2366404
Look at item 17  - put that part number into eBay and Google for the price and how to at audizine.com
Offline white91
« Reply #2 on: January 04, 2016, 08:40:03 pm »
Mine the same after VW did an 'upgrade'
Offline Bo!
« Reply #3 on: January 04, 2016, 08:45:35 pm »
Thanks for the speedy replies .
Do I need to do this or will they be ok left like they are they are, there in place and the engine covers back on could they wiggle out .?
Offline doylebros
  • -Receive: 310
« Reply #4 on: January 04, 2016, 08:48:01 pm »
It will fail - the sooner you get it done the cheaper the bill will be!
Offline white91
« Reply #5 on: January 04, 2016, 11:13:19 pm »
Looks like I better get a set ordered then, let me know if you find where sells them
Offline toosmiles
  • -Given: 22
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92286.0.html
Golf R mk6 R-tech tuned GTX3071r
Offline Bo!
« Reply #7 on: January 05, 2016, 11:34:20 am »
Spoke someone down at ECP they can do these £7.90 each
Offline white91
« Reply #8 on: January 05, 2016, 11:42:58 am »
Have you spoken to TPS?
Offline Bo!
« Reply #9 on: January 05, 2016, 05:08:18 pm »
No not spoke to TPS .
Cars still under warranty from VW and I'm going to phone and ask them why they sold me the car with these broken to see if I can get them to replace when I take it in for a service got to be worth a shout .
Offline white91
« Reply #10 on: January 05, 2016, 06:09:59 pm »
Yeah certainly worthwhile asking
