Author Topic: Can you check CANBUS version with out VAG COM ???  (Read 5183 times)
Offline Hannakournikova
« on: January 17, 2016, 01:44:46 pm »
Have tried a search but getting conflicting info.
Can i check what version CANBUS i have fitted to my 03/07 date golf by the sticker on it?
« Last Edit: January 17, 2016, 01:57:18 pm by Hannakournikova »
Offline Nasir
Re: Can you check CANBUS version with out VAG COM ???
« Reply #1 on: January 17, 2016, 02:54:27 pm »
Most likely will need changing. You could tell by taking it out I guess.
Mine is registered 03/07 and needs changing.
« Last Edit: January 17, 2016, 06:06:55 pm by Nasir »
Shadow Blue 2007 GTI DSG (Standard)
Offline aadilp1
« Reply #2 on: January 17, 2016, 03:11:20 pm »
I had a Jetta 2006 56 and the Gateway didn't need changing - hit n miss I guess
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #3 on: January 17, 2016, 05:33:59 pm »
What's the version that you have?
Offline aadilp1
« Reply #4 on: January 17, 2016, 05:44:51 pm »
Sold the car sorry, wouldn't know now
« Reply #5 on: January 24, 2016, 06:57:49 pm »
Ok so I gave it it my best gymnastic impersonation today trying to find the canbus.
Nothing there. Not in the places advised on Google images.
Above pedals - no
Behind relay board - no
Behind foot rest - no
Behind cubby hole - no
Where else?
Offline aadilp1
« Reply #6 on: January 29, 2016, 06:51:43 pm »
definitely above the pedals mate, keep looking
you will find the gateway connected with a red connector!
« Reply #7 on: March 22, 2016, 07:53:06 am »
just to fill in the blanks incase it helps someone else.
Turned out to be behind the relays in the cubby storage area. What a kunt to get at.
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
« Reply #8 on: March 22, 2016, 11:59:30 am »
I found this website helpful time and again:
http://www.my-gti.com/2296/can-bus-gateway-removing-installing-and-upgrading-volkswagen-golf
Also if you go into the module in VCDS before removing your old Canbus you should be able to read its part number. If it's removed already it's well worth updating to a 7N0... Canbus. You can then retrofit and mod you Golf to your hearts content. :happy2:
