September 01, 2026, 07:45:37 pm
All Things Mk5
How to Guides / Troubleshooting
DPF diesels?
Topic: DPF diesels? (Read 1687 times)
Vwgtiking
Won't Shut up.
-Given: 4
-Receive: 3
DPF diesels?
February 09, 2016, 07:55:41 pm »
Found a cheap 170 Passat but he says it has dpf issues. Whereby he drives on the motorway it then goes into limp mode. Switches off the engine, restarts and car is fine again. Does this sound like something cheap or I could even fix?
RetroRaz
Just look at my post count
-Given: 32
-Receive: 194
Re: DPF diesels?
Reply #1 on:
February 09, 2016, 08:21:22 pm »
Dpf removal might fix it but not sure if emissions test has changed on that now for MOT
#RetroRaz -
https://instagram.com/retroraz/
doylebros
-Given: 44
-Receive: 310
Re: DPF diesels?
Reply #2 on:
February 09, 2016, 08:54:05 pm »
You've got to start with a scan (cheapest first) as plenty people want to bail out of their vehicle first sign of a bill over £500.
xjay1337
-Given: 15
-Receive: 377
My Ride:
Re: DPF diesels?
Reply #3 on:
February 10, 2016, 12:09:17 am »
Not an issue. Cut and weld old dpf.
However doesnt sound like a dpf issue. Sounds like turbo under or overboost. Fairly common on 170 tdi engines is issue with actuator on turbo. Can be replaced separate.
Click for build thread
Stage 2 GTI Purple Scene Queen
221bhp/365lbft TDI build
Detailing Guide
Wheel Fitment Guide
All Things Mk5
DPF diesels?
