Author Topic: Drivers door won't lock using key fob  (Read 10733 times)
Offline DeadMau5
« on: February 17, 2016, 07:23:07 pm »
Hi, I have a problem with my mk5 golf r32 where the drivers door won't lock using my key fob. It locks fine using the blade. If I lock using the key fob and open the door the alarm sounds.
Any help would be appreciated
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
Re: Drivers door won't lock using key fob
« Reply #1 on: February 17, 2016, 07:30:14 pm »
Have a look at the wiring between the door and body as the wires may have broken
Offline DeadMau5
« Reply #2 on: February 17, 2016, 07:47:14 pm »
Ok thanks will check, lads on r32oc recon it the door lock module, sounds an expensive part lol
Offline TAPPY
  • -Receive: 56
« Reply #3 on: February 17, 2016, 07:49:51 pm »
Yeah it could be that but I would check the wires first as might be a quick fix  :happy2:
Offline DeadMau5
« Reply #4 on: February 17, 2016, 07:52:27 pm »
Worth a check as the part is over 100 quid new! Ouchhhh
Offline doylebros
  • -Receive: 310
Offline DeadMau5
« Reply #6 on: February 17, 2016, 08:07:57 pm »
Ok cheers
Offline DeadMau5
« Reply #7 on: February 18, 2016, 11:47:01 am »
Tried spare key which is the old one (the one I use all the time is new 12 months old) and it works fine with spare key lol
Offline doylebros
  • -Receive: 310
« Reply #8 on: February 18, 2016, 10:06:30 pm »
I feel the fault will return regardless of which FOB is used - door wiring would be my thoughts as the most likely issue.
I would be interested in an update after you've given the fault a chance to return.
Offline DeadMau5
« Reply #9 on: February 19, 2016, 06:21:48 am »
I removed door gaiter to check wires and unplugged the loom. Put it back together,  used spare key and it worked. Like you said I think I've disturbed something
Offline DeadMau5
« Reply #10 on: March 04, 2016, 02:53:39 pm »
Right, thought I would update this. The problem returned so I thought I would try my luck and buy a new lock mechanism off eBay (bad move). Booked the car in with joe from Leominster vag tech to replace it and then found the door locked but wouldn't unlock lol. Luckily he knew a few tricks to unlock it and it eventually unlocked. I then knew I had to buy a new genuine one so £165 later for the new part joe fitted it and all is working again. Lesson learnt there haha.
« Last Edit: March 04, 2016, 05:10:09 pm by DeadMau5 »
Offline pjuster
« Reply #11 on: March 11, 2016, 10:18:35 am »
Hi DeadMau5,
Can you elaborate on why it was a bad move to buy one of ebay, I've done the same and am planning to fit it next week.  What was wrong or the problem with the ebay one ?
I've bought one of these
http://www.ebay.co.uk/itm/OEM-Rear-Right-Door-Lock-Latch-Actuator-For-VW-Jetta-Golf-GTI-MK5-Touran-Touareg-/221463070036?hash=item33903a4554
any info gratefully received.
