Author Topic: Missfire. need help asap  (Read 2891 times)
Offline K9
  • VW LifeStyle
« on: April 11, 2016, 05:15:33 pm »
Sup. i'm getting codes like random missfire and 2 codes that say cylinder 1 & 4, this only happens sometimes when pushing true gears to redline. runnng stage 1+ with v-power.
what should i check first?
Offline dronners
Re: Missfire. need help asap
« Reply #1 on: April 11, 2016, 05:20:29 pm »
coilpacks and sparkplugs first port of call id say
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #2 on: April 11, 2016, 05:42:22 pm »
As above, plugs, i've replaced two in the last 2 weeks
Offline K9
  • VW LifeStyle
« Reply #3 on: April 11, 2016, 05:50:12 pm »
will check tomorrow  :happy2:
Offline shoaybmakda
  • -Receive: 54
« Reply #4 on: April 11, 2016, 06:12:58 pm »
This.
If these are fine then could be your injectors as I eventually found out. But definitely start at that point first.
Offline Johal87
« Reply #5 on: April 11, 2016, 07:14:43 pm »
I just had this, mine was injector 3, did plugs first, but because it was the injector it messed that plug up again so had to do the plugs again anyway
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #6 on: April 11, 2016, 08:33:45 pm »
I always have new coils in the garage because they will cause misfires when they begin failing rather than reaching complete failure. If I swap one out and the problem is fixed...it was the coil. If not I check the plugs and replace if nearing the time when I usually replace them...and by checking I mean I gauge them and replace if their gap has increased. If the gap is larger...you have burned through their coating and pointless to re-gap. If still exists...the injectors, but haven't had to go that far yet being at 127k miles total with just 67k miles on the S3 injectors that were installed with my K04 upgrade.
Offline K9
  • VW LifeStyle
« Reply #7 on: April 13, 2016, 10:57:07 am »
whats hould the gap be between NGK plugs? they were now 0.80
