September 23, 2026, 04:55:39 am
All Things Mk5
Mk5 General Area
Changing brake discs and pads
Topic: Changing brake discs and pads (Read 1420 times)
howie1987
Won't Shut up.
-Given: 92
-Receive: 21
April 15, 2016, 10:15:44 am »
Am changing brake discs and pads at the weekend on my edition 30.
Is it just a matter of changing them and topping up my brake fluid. or do i need to plug it in to vdcs?
Idealy i was going to change the brake fluid aswell but am reading i need vdcs which i don't have.
dazza
Admin
Just look at my post count
-Given: 90
-Receive: 190
Coding Boffin
My Ride:
Re: Changing brake discs and pads
Reply #1 on:
April 15, 2016, 10:17:22 am »
I changed mine a couple of years ago without vcds.
05 | Tornado Red | DSG
howie1987
Won't Shut up.
-Given: 92
-Receive: 21
Reply #2 on:
April 15, 2016, 10:56:13 am »
i'll give it a bash see how it goes then.
Paradox1
-Given: 41
-Receive: 82
Reply #3 on:
April 15, 2016, 11:33:59 am »
You don't need to VAGCOM to change the fluid. only if you want to drain the ABS Pump.
When you push the pistons back, you will need to open the brake res. when you push the piston back the fluid will go back to the original level
All Things Mk5
Mk5 General Area
