Author Topic: Rear pad removal  (Read 6078 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Rear pad removal
« Reply #15 on: May 06, 2016, 07:59:25 pm »
You won't be able to work it back out lol
If the rubber dust seal turns with the piston get some wd 40 or similar lubricant under the rubber cap and you'll free it up. Remember it's just a dust cover.
Offline Lewo
« Reply #16 on: May 06, 2016, 08:30:17 pm »
Wouldn't a few pumps on the brake pedal work the piston out?
Serious question btw, I've worked on mtb brakes this way to good effect but not got a clue with cars  :thinking:
« Reply #17 on: May 06, 2016, 08:36:45 pm »
Why would you need to work them in an out?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #18 on: May 06, 2016, 08:49:11 pm »
There is no need to work them in and out so just wind them back and job done. :happy2: pump them out with the foot brake and they'll work their way out and then you'll be back on the forum crying that your pistons have come out and you can't get them back in  :signLOL:
Offline Lewo
« Reply #19 on: May 07, 2016, 03:37:09 pm »
On mtbs if the pistons are sticking you can use a bit of silicon lube/brake fliud on the piston seals and work then in and out a few times which usually sorts it.
Not the same process on cars then obviously then  :signLOL:
Just wondered if it's good preventative maintenance that's all.
