Author Topic: ChrisGT's Black 5 door GT TDI 170  (Read 113032 times)
Offline ChrisGT
Re: ChrisGT's Black 5 door GT TDI 170
« Reply #75 on: September 06, 2016, 12:20:39 pm »
Gave the car a quick auto scan and it threw up 5 codes.
the egr one I knew about as it has been blanked off but not mapped out yet.
The abs and esp lights have been coming on intermittently lately while driving but always go off as soon as the car is switched off and switched on again. The scan suggests it's a wheel speed sensor at the rear left. I believe from research on the forum and other forums that the wheel bearing can be the culprit for this error so will get that checked out soon enough. Not too worried about it though.
The other codes I'll look into as I didn't know about them. The drivers window works perfectly though as does the intermittent wipe of the wipers.
Here are the modules which threw up codes.
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 DF    HW: 03G 906 018 DF
   Component: R4 2.0l PPD1.2      0428
   Revision: --H42---    Serial number: VWZ7Z0G8043698
   Coding: 0000072
   Shop #: WSC 06441 785 00200
   VCID: 6CD79A974F70432264-8038
1 Fault Found:
001025 - EGR System
               P0401 - 006 - Insufficient Flow - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100001
                    Fault Priority: 1
                    Fault Frequency: 92
                    Reset counter: 40
                    Mileage: 102088 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:29:29
             Freeze Frame:
                    RPM: 1824 /min
                    Torque: 144.0 Nm
                    Speed: 69.0 km/h
                        84.63 %
                        95.55 %
                    Mass Air / Rev.: 523.2 mg/str
                    Mass Air / Rev.: 823.0 mg/str
Readiness: N/A
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0023170
   Shop #: WSC 01392 785 00200
   VCID: 73E581EB124E9CDAA5-8026
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
            003 - Mechanical Failure - Intermittent
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000012
   VCID: 74E782F717409BE2BC-8020
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 060207F1000897
   Coding: 3D3F034007000003
   VCID: 2F6D4D9BBEE6F83A01-807A
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 38
                    Mileage: 75571 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:16:09
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
   Component: Tuer-SG         005 0988
   Coding: 0000692
   VCID: 387F76C74BA83F8250-806C
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation
End-------------------------(Elapsed Time: 01:51)--------------------------
If anyone recognises the other codes then feel free to enlighten me.
Cheers,
Chris
« Last Edit: September 06, 2016, 12:24:16 pm by ChrisGT »
Offline ChrisGT
« Reply #76 on: September 07, 2016, 05:16:11 pm »
The other day the heater started only working when on setting four... so it was either off or on full blast... Funny but not useful.
I had a similar problem a few years ago with my mk3 golf and it was the resistor pack that stopped working, I figured it was a similar problem. Google and searching the forum confirmed it, so I bought a new resistor pack for about £12 off ebay.
This is the new one which arrived super quick as I only ordered it on Monday evening and arrived today (wednesday) lunch time.
Was really easy to replace, just drop the foam out from under/behind the glove box and then it's right there, pulled out the old one and put in the new one, plugged it back in and all working perfectly again  :happy2:
Here's the two side by side:
Guess it'll be the original one. Have heard that sometimes the motor is starting to fail which causes the resistor pack to fail so will keep an eye on that. If the resistor pack fails again then I'll replace the motor too.
Chris
Offline ChrisGT
« Reply #77 on: September 28, 2016, 12:06:04 pm »
Been getting quite a bit of noise from the clutch release bearing lately.
If the gearbox is coming off to replace that I figured I might as well replace the clutch friction plate and dmf so ordered the full sachs kit and it arrived yesterday. Just need to get it booked into the garage to get it done. Not a job I'm confident enough to do myself.
Got my new wheels all polished up and sealed with Gtechniq C5 and EXOv2 so just need to get them balanced and then can fit them.
Chris
Offline ChrisGT
« Reply #78 on: October 02, 2016, 03:29:09 am »
Finally got around to fitting my new wheels today.
I bought them form a forum member a while ago and they were in good condition having been refurbished/powder coated not too long ago.
I gave them a good freshen up though with the following process:
Removed all old wheel weights,
Washed with bilberry wheel cleaner and various brushes,
Sprayed with ironx and left for a few minutes and then washed with Bilberry again to remove any ironx residue,
Dried,
polished with DA with mequiar's 205 and a microfiber pad,
Sealed with Gtechniq C5 and then coated with EXOv2,
re-balanced.
So here's the new wheels next to the old ones, a few pictures of them next to each other and then old and new on the car.
Really pleased with them and they will be really easy to keep clean now they're all sealed up.
While I had the front passenger side wheel off I noticed there is a cutout in the arch liner and you can see the end of the gearbox, there's a cap which appears to be seeping some fluid so have ordered a replacement as this seems to be fairly common and just need to replace the cap. cap part number is 02M301211B
Cheers,
Chris
Offline ChrisGT
« Reply #79 on: October 04, 2016, 03:51:15 pm »
took the front arch liners out to clean in behind them.
Really wasn't too bad, quite a few little stones etc but nothing major.
I also removed the foam from behind the wheel arch. These are the bits of foam that cause all the rust problems with the outer arches. they soak up water and hold it right against the edge/seam of the arch and of course they rust because they never dry out properly. Both arches have tiny amount of bubbling where the foam has been so will need replaced at some point but they're fin for now.
As you can see from the picture below, the ends of the foam are still full of water and it's been a few days since it rained/roads were wet.
Chris
Offline ChrisGT
« Reply #80 on: October 08, 2016, 06:27:53 pm »
Got some wheel nut covers to go with my new wheels. The centre caps on the old wheels covered them but now they're exposed so just helps neaten them up a bit. Gave them a coat of Gtechniq EXOv2 to help protect them and so they're easy to keep clean.
Got them on amazon for about £15 but they're a great fit and have the Volkswagen lettering on them. They came with the little metal pick to remove them too so have put that in the space in the boot that's cut into the polystyrene.  :happy2:
Offline ChrisGT
« Reply #81 on: October 15, 2016, 10:20:44 pm »
Gave the wheels a wash today, got to love well sealed wheels! So easy to clean and bead up nicely.
Thanks for looking,
Chris
Offline marko
« Reply #82 on: October 16, 2016, 06:05:32 pm »
Great write up so far pal from a fellow 170gt owner!!
Offline ChrisGT
« Reply #83 on: October 16, 2016, 08:14:52 pm »
Thanks very much Marko  :drinking:
Have you got a build thread too, going by the list in your sig then you've done a lot to it?
Cheers,
Chris
Offline SeyiiOluwa
« Reply #84 on: October 18, 2016, 01:28:07 pm »
Thanks very much to both of you  :happy2:
I bought smoked ones from ebay.
I followed the instructions in this video:
and it was fairly easy. One of the clips on the old indicator broke as I removed the top cover as you can see in the picture with the old and new ones side by side but not too bothered. Was going to keep them as spares so have kept the other one but just dumped the one with the broken clip.
Yeah, I'll keep a look out for the ones with black inserts as I think they'd look much nicer than the standard silver ones.
Chris
Have you got a link for the smoked indicators ? Looks real nice
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #85 on: October 18, 2016, 02:04:33 pm »
Chris
Wait, what's that? Control for heated seats?
Offline ChrisGT
« Reply #86 on: October 18, 2016, 07:12:32 pm »
Chris
Thanks, I'm pleased with them.
This is the link to the ones I bought but there are loads on ebay if you search for "mk5 golf smoked indicators":
http://www.ebay.co.uk/itm/FORD-SEAT-SKODA-VOLKSWAGEN-1-PAIR-OF-WING-DOOR-MIRROR-INDICATORS-SMOKED-/201279548322?hash=item2edd322ba2:g:x3AAAOSw5VFWPN9d
Cheers,
Chris
Offline ChrisGT
« Reply #87 on: October 18, 2016, 07:16:07 pm »
Chris
No, I don't have heated seats. It's the resistor pack for the heater blower. It would only work on setting four but has worked perfectly since I replaced the resistor pack  :smiley:
Chris
Offline ChrisGT
« Reply #88 on: November 05, 2016, 07:50:57 pm »
Had the car remapped today by celtic tuning. Mainly to get rid of the EGR functionality as it has been blanked off but also had him put on the celtic tuning stage one map instead of the superchips one that was on it.
All good but engine management light still on so scanned the car, been about a month since I scanned it last, and it's thrown up this:
   Coding: 0000072
   Shop #: WSC 66565 257 00032
   VCID: 6CD79A974F70432278-8038
1 Fault Found:
005213 - Exhaust Gas Temperature Sensor 3
               P145D - 006 - Short to Plus - MIL ON
             Freeze Frame:
                    Fault Status: 11100001
                    Fault Priority: 1
                    Fault Frequency: 4
                    Reset counter: 40
                    Mileage: 105663 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:15:54
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Temperature: 39.0°C
                    Text:  188    C
                    Text:  144    C
                    Text: 1000    C
                    Raw, Form. N/A: 000 000 000
So, going to need to get a new sensor. Pretty sure it's the sensor with part number 003G906088D.
Offline Adamcrake1991
    • My GTTDi 140
  • My Ride: Mk5 GTTDi 140
« Reply #89 on: November 05, 2016, 08:23:41 pm »
Changed over indicators for smoked ones which I think look much neater.
Before:
After:
I think it looks much neater now, they were a bit fiddly but fairly easy to change, was quite dirty inside so was a good chance to clean out the insides.
On the lookout for some genuine GTI headlights with the black inserts too. Not sure about the replica style ones on ebay if they'd be any good so think I'll hold out for some genuine ones. There were a pair for sale on here about a week ago but I didn't have enough posts to post on the thread or PM the seller and they're sold so will keep my eyes peeled.
Chris
Hello Chris looking spot on so far mate look forward to seeing more updates, out of interest where did you get these smoked indicators from mate thy look awesome and would love them on my GTTDi
Thanks adam
