Author Topic: sharan ariel  (Read 6006 times)
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
sharan ariel
« on: January 14, 2010, 04:54:54 pm »
Hi guys is the sharan stubby a straight forward fit, or does the base plate need re-drilled ?
also is there any loss in reception ?
Has anyone got the part number for it ??
7m0035849 e possibly ??
MK7 GTI - ARRIVING DECEMBER
Offline bacillus
  • -Receive: 453
Re: sharan ariel
« Reply #1 on: January 14, 2010, 11:04:16 pm »
I'm sure it's the same as the replica ( http://www.parts4euro.com/DCShop/product_info.php?cPath=1_35_263&products_id=8  ) in which case just unscrew your present aerial and replace it with the Sharan one.  :smiley:
Offline pako88268
  • Always driving slowly =)
Re: sharan ariel
« Reply #2 on: January 15, 2010, 01:41:21 am »
I got this http://www.parts4euro.com/DCShop/product_info.php?cPath=1_35_263&products_id=8 and it fit straight away no problem with reception.
REVO Stage 2+, Dbilas intake, KMD High Pressure Fuel Pump, Sachs organic clutch, Sachs Single Mass Flywheel, BSH Oil catch tank, BSH Engine mount, BSH transmission mount, BSH lower mount, Milltek downpipe, 200 cells cat back, HKS Turbo Timer, FORGE DV Valve, FORGE Spacer, THS -intercooler, OZ, etc
Offline GTIjames
Re: sharan ariel
« Reply #3 on: January 15, 2010, 09:00:50 am »
Offline Oli
  • -Given: 19
Re: sharan ariel
« Reply #4 on: January 15, 2010, 09:40:12 am »
Thanks James, just ordered one
Offline andrewparker
  • -Given: 32
  • -Receive: 78
Re: sharan ariel
« Reply #5 on: January 15, 2010, 12:37:41 pm »
Yep, I've got that one off ebay and it is absolutely fine, a good improvement over the standard aerial, and no reception problems.
Offline scarpicus
Re: sharan ariel
« Reply #6 on: January 15, 2010, 01:01:10 pm »
that aint cheap - ebay is your friend for this £8.75 delivered - works well and no problem with reception either  :happy2:
http://cgi.ebay.co.uk/Short-Stubby-OEM-Aerial-fits-Sharan-Golf-Polo-Lupo_W0QQitemZ220529605526QQihZ012QQcategoryZ36676QQcmdZViewItemQQ_trksidZp4340.m444QQ_trkparmsZalgo%3DCRX%26its%3DC%252BS%26itu%3DSI%252BUA%252BLM%252BLA%26otn%3D5%26ps%3D63
I just got that one delivered this morning but not entirely happy with it as it does not sit flush with the base..... :sad1: there is a gap of about 5mm between bottom part of sharan ariel and base....although some people might not be bothered by that i'm not sure it looks right.
other than that it works fine but having said that if i dont put the Sharan or orignal ariel on the base my car still seems to pick up reception just as good.... :surprised:
if the gap still annoys me after a few days i'm just leave the ariel off since i'm still getting reception to the only stations i listen to Rinse fm and talksport.
  • -Given: 64
  • -Receive: 48
Re: sharan ariel
« Reply #7 on: January 15, 2010, 06:18:19 pm »
Im not sure if this is the problem with yours but i had this problem on another car i changed my ariel on but..................................
Make sure that the threaded part of the Sharan ariel is not too long and bottoming out on the short thread of the standard ariel mount. If it is simply cut a few mm from the sharan stubby thread,
let me know if this has worked please, if not im thinking of the s2000 ariel now
  • -Given: 32
  • -Receive: 78
Re: sharan ariel
« Reply #8 on: January 17, 2010, 07:32:43 pm »
Yep, if you compare your standard aerial to the Sharan replacement you will notice that the threaded piece on the standard aerial is much shorter, so you need to lop off 3 or 4mm for it to sit flush.
Offline scarpicus
Re: sharan ariel
« Reply #9 on: January 18, 2010, 10:57:19 am »
il give that a try.... :happy2:
Offline Oli
  • -Given: 19
Re: sharan ariel
« Reply #10 on: January 18, 2010, 12:20:06 pm »
Got mine today, I'll check the length and let you know about the thread length.
Offline markymark
Re: sharan ariel
« Reply #11 on: January 18, 2010, 12:47:28 pm »
I bought mine from here http://www.mazda3forums.com/enigma/antenna.html it came from Canada. Bought mine about 2 years ago now and its great!
Re: sharan ariel
« Reply #12 on: January 18, 2010, 12:51:19 pm »
:chicken: :grin:
Offline scarpicus
Re: sharan ariel
« Reply #13 on: January 18, 2010, 01:26:15 pm »
that gap is acceptible but mine is a more than that but i'l do what gobble and andrew said jus chop off some of the thread part.... :happy2:
Offline scarpicus
Re: sharan ariel
« Reply #14 on: January 18, 2010, 01:28:46 pm »
:chicken: :grin:
VC have u or anyone ever eaten that....looks... :sick:  :signLOL:
