Author Topic: Sound deadening  (Read 2724 times)
Offline Madone
  • -Receive: 27
Sound deadening
« on: June 09, 2016, 10:23:20 am »
Hi All,
Has anyone fitted and sound deadening in the doors etc ?, I see the MKV allows you to remove the door skins from the door, has anyone done it this way or do you remove the door cars and go from the inside ?
Offline theminty1
Re: Sound deadening
« Reply #1 on: June 09, 2016, 10:32:41 am »
You need to remove the doors skins as there is no access by removing the door interior trim. if you do a search there have been several people have done it. Door handle and correct order for returning the screws are points to note.
140 BKD GT TDi  5dr
Offline Madone
  • -Receive: 27
Re: Sound deadening
« Reply #2 on: June 09, 2016, 10:52:45 am »
Ok, sounds interesting way to do it !
I guess most people do the doors and boot floor ?
Offline theminty1
Re: Sound deadening
« Reply #3 on: June 09, 2016, 11:36:22 am »
Different yes but it can give you a chance to check over the window winder wires etc.
Boot floor, doors and under rear bench seat.
http://forums.vwvortex.com/showthread.php?2984471-DIY-Passenger-Side-Door-Skin-Removal
http://www.golfmkv.com/forums/showthread.php?t=10694
etc
« Last Edit: June 09, 2016, 11:40:03 am by theminty1 »
140 BKD GT TDi  5dr
Offline Madone
  • -Receive: 27
Re: Sound deadening
« Reply #4 on: June 09, 2016, 12:03:52 pm »
Cheers ! :happy2:
