Author Topic: BCS DOWN PIPE AND SPORTS CAT  (Read 2072 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« on: July 31, 2016, 01:54:55 am »
What size gasket to the matting faces?. 3 inch ?
Re: BCS DOWN PIPE AND SPORTS CAT
« Reply #1 on: July 31, 2016, 02:17:33 am »
You mean turbo flange gasket? Just get an OEM one from vw
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: July 31, 2016, 02:22:22 am »
I need to get that with 4x bolts and nuts but I mean the down pipe to cat.
« Last Edit: July 31, 2016, 02:49:10 am by r5gtt »
« Reply #3 on: July 31, 2016, 09:01:23 am »
The downpipe and cat is all one bit. Not sure what you are asking .....
Offline v4rley
  • -Receive: 104
« Reply #4 on: July 31, 2016, 09:16:46 am »
No he's using the Quattro setup, so in two pieces
« Reply #5 on: July 31, 2016, 09:25:54 am »
Ohh ok.
Btw the turbo flange is studded so you only need new nuts if you really want to change them
Not sure about the dp connector. But the internal diameter will be 3"
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: July 31, 2016, 10:01:52 am »
Thanks @v4rley sorry I should have mentioned I'm using the Quattro set up.
My bad @rich83  Two studs are stripped from before and two have snapped, one whilst undoing it and the other whilst doing up. both front upper and lower ones so in a predicament atm and have to be changed along with the nuts :sad1:
stupidly watched a YouTube video and thought peace of P.  :slap:
« Last Edit: July 31, 2016, 10:08:09 am by r5gtt »
« Reply #7 on: July 31, 2016, 10:03:34 am »
Ahh bollocks.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: July 31, 2016, 10:08:32 am »
Yes defo  :doh: will be doing it next weekend not thay I want to go inot work as he'd want me to fit up a few cars before I start on mine. orderes a set of stud removers last night as I don't have any.
« Last Edit: July 31, 2016, 10:21:55 am by r5gtt »
