Author Topic: Anti lift kit - how much to install?  (Read 8058 times)
Offline bad devotions
  • -Given: 19
« on: August 07, 2016, 12:39:41 am »
As per the title, how much should the install cost? Is it a simple thing for a garage to do?
I am assuming this is not something that I can do :)
Sent from my Nexus 5 using Tapatalk
  • -Given: 19
Re: Anti lift kit - how much to install?
« Reply #1 on: August 08, 2016, 10:10:33 am »
no replies from anyone, but just had one quote at £70+VAT for fitting. Will take a couple of hours too. Does this sound about right? Anyone? Bueller?
Offline jayha11
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97064.0.html
« Reply #2 on: August 08, 2016, 10:12:56 am »
Where are you based?
Mk5 GTI > S3 8P > Cupra 300 > Cupra 290 > Mk5 R32
« Reply #3 on: August 08, 2016, 10:15:35 am »
Needs alignment too once fitted
  • -Given: 19
« Reply #4 on: August 08, 2016, 10:22:15 am »
based in chorley.
  • -Given: 19
« Reply #5 on: August 08, 2016, 10:22:38 am »
good to know - thanks.
Offline raz469
« Reply #6 on: August 08, 2016, 11:33:10 am »
Anti lift is pretty simple tbh.
Lift car, undo 3 bolts at ball joint undo bolts connecting bush housing to sub frame. Pull the old kit off and push on the new.
Tracking will take longer to do.
  • -Given: 19
« Reply #7 on: August 08, 2016, 03:32:34 pm »
thanks for that. Again, good to know. I'll check with my local garage if they can do all that. They are usually pretty good so we'll see.
Offline mvb12
  • -Receive: 64
« Reply #8 on: August 08, 2016, 03:44:45 pm »
Basically 1hours work max.
if £70+ vat is the hourly labour charge than i would say thats correct.
  • -Given: 19
« Reply #9 on: August 08, 2016, 04:44:00 pm »
Thanks mvb12.
I've just popped to see my local garage who said it'll be £20 per side plus time to do tracking. So anything between £60 and £100 inc VAT. Booked in for Friday :)
Offline Paradox1
  • -Given: 41
« Reply #10 on: August 08, 2016, 04:52:56 pm »
Its really straight forward to do. I think Id do it mmyself and get the tracking done afterwards at garage as long as you dont have far to drive
  • -Given: 19
« Reply #11 on: August 08, 2016, 05:09:01 pm »
yeah i am time poor unfortunately and £20 a side is decent. Like i say, i trust that garage so am happy to pay them.
Offline patpong_pete
« Reply #12 on: August 09, 2016, 12:18:46 pm »
let us know what its like after ?
its meant to be a good mod
« Reply #13 on: August 09, 2016, 01:08:57 pm »
Long as the bolts dont snap its quite easy to do
  • -Given: 19
« Reply #14 on: August 09, 2016, 02:03:37 pm »
@patpong_pete will do mate - looking forward to having it done.
