Author Topic: F1 paddles  (Read 2269 times)
Offline JASGTI
F1 paddles
« on: August 08, 2016, 03:52:45 pm »
Good afternoon
After making the mistake of selling my 300bhp mk5 gti 2 years ago for a new tiguan r line for the wife, I'm now in a position to buy another one. Iv found a nice dsg but doesn't have the paddles.  What sort of price are the parts as can fit it all myself.
Cheers Jason
Mk5 Gti, dsg 5door.
Offline Paradox1
  • -Given: 41
Re: F1 paddles
« Reply #1 on: August 08, 2016, 03:58:22 pm »
Id imagine you'd need the oem paddles and a wiring loom as well as someone who knows what there doing in Vag com to code the paddles in.
Think it would be easier, cheaper to just buy a motor with the paddles as OEM unless you don't mind a bi of a retrofitting
Offline JASGTI
Re: F1 paddles
« Reply #2 on: August 08, 2016, 08:19:30 pm »
Yeah iv got vag com so the fitting and coding is OK, I'm just trying to see if it's just a wheel with paddles and coding or do I require control modules and wiring.
Mk5 Gti, dsg 5door.
Offline irish_ram
  • -Given: 200
Re: F1 paddles
« Reply #3 on: August 09, 2016, 12:26:47 pm »
Might be wrong but when you say paddles do you mean the attachment ones you can fit to thegear change switches with +/- on back of steering wheel. Only reason I ask is I presumed all DSG's came with the steering wheel gear selectors but later models had actual paddle extension attached
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
Re: F1 paddles
« Reply #4 on: August 09, 2016, 12:57:56 pm »
No, later models still have the same small paddles.
You need to retrofit a steering wheel with paddles, might also need to replace your steering wheel module and code it.
If you want bigger paddles, you glue extension paddles like I did. :wink:
Offline JASGTI
Re: F1 paddles
« Reply #5 on: August 09, 2016, 11:00:28 pm »
Think it will require a wheel as has the basic wheel fitted, so looking around 400-500 part price depend I suppose. Cheers chaps
Mk5 Gti, dsg 5door.
