Author Topic: SNAPPED INLET CAM  (Read 2199 times)
Offline Sammasson
SNAPPED INLET CAM
« on: October 05, 2016, 08:58:51 am »
I've jut bought an engine with a snapped inlet cam, it snapped right next to the fuel pump cam, would it be just replace the cam or would there be more to it?
Offline DANBOY66
  • -Given: 41
Re: SNAPPED INLET CAM
« Reply #1 on: October 05, 2016, 12:57:10 pm »
i would put a cam in it and time it up then turn it over by hand to see if it spins freely
also check the both cam journals for scoring
Dan..
Offline Sammasson
« Reply #2 on: October 05, 2016, 01:36:57 pm »
That's what I thought just wasn't sure if it would of bent valves?
Offline DANBOY66
  • -Given: 41
« Reply #3 on: October 05, 2016, 01:43:10 pm »
until you turn it over you will not know
i removed a head the other day after an axx engine code tensioner chain had snapped quite badly it smashed the casing to bits and ripped a tooth of the exhaust cam sprocket
it never bent any valves i was amazed  :happy2:
Dan..
Offline Sammasson
« Reply #4 on: October 05, 2016, 01:53:53 pm »
Okay thanks
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: October 06, 2016, 12:29:15 am »
Is that the one off FB?.if so just replace the cam and that will see you right
Offline DANBOY66
  • -Given: 41
« Reply #6 on: October 06, 2016, 05:18:15 am »
when my chain snapped it didnt bend any valves.
Interesting to see two engines with snapped chains that didnt bend valves. Was your snap at idle as well @DANBOY66
I bought the car with the snapped chain so who knows it's made a mess of itself smashed itself to bits
Dan..
