September 03, 2026, 10:49:35 pm
All Things Mk5
Mk5 General Area
Burning spark plug out
Topic: Burning spark plug out (Read 1859 times)
P30egy
Just Arrived
-Given: 0
-Receive: 0
October 07, 2016, 08:00:58 am »
Here goes had a coil pack problem replaced and the mechanic noticed the plug had burnt out, around 5k later misfire started same plug as burnt out again. Oil consumption is the same any ideas what this could be thanks in advance
P30egy
Just Arrived
-Given: 0
-Receive: 0
Re: Burning spark plug out
Reply #1 on:
October 07, 2016, 08:01:51 am »
Forgot to mention mileage is 125k totally standard gti
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 692
Reply #2 on:
October 07, 2016, 09:42:53 am »
Burned out usually means running too hot. If the plugs are OEM ones, then it's probably down to a bad injector. You might want to get that confirmed and replaced before detonation destroys the piston.
All Things Mk5
Mk5 General Area
