Author Topic: Does Disconnecting battery lose your map?  (Read 2565 times)
Offline jaylufc17
  • -Given: 48
« on: October 13, 2016, 07:45:01 am »
So changed coil packs an drew spark plugs so obviously battery was disconnected... someone said that you may lose your map if the battery is disconnected? Is this true? Cars not warm at the moment so haven't really tested and was on stage 1 map before
Re: Does Disconnecting battery lose your map?
« Reply #1 on: October 13, 2016, 08:08:54 am »
all depends who mapped the car,if it's a revo map it will set to basic settings
Offline bonelorry
  • -Given: 72
  • -Receive: 44
« Reply #2 on: October 13, 2016, 08:50:57 am »
You do not need to disconnect the Battery when replacing the Coil-Packs or Spark Plugs  :smiley:
Offline jaylufc17
  • -Given: 48
« Reply #3 on: October 13, 2016, 12:50:08 pm »
Midlands remaps... traction light still comes on the same as before in 1st gear so seems like it hasn't lol!
I just followed a video on YouTube and they disconnected the negative terminal
Offline ducman77
  • -Given: 59
« Reply #4 on: October 13, 2016, 01:44:34 pm »
I've disconnected battery loads of times with no effect on my map. But it's a custom map, so can't really comment for any other types of map
Offline welshname
« Reply #5 on: October 22, 2016, 09:34:47 pm »
Are you serious?  The revo map goes if you disconnect the battery?  That can't be right at all
« Reply #6 on: October 22, 2016, 11:20:14 pm »
It reverts to basic low boost settings.
Offline grey golfster
  • -Given: 79
« Reply #7 on: October 23, 2016, 10:26:56 am »
My APR 2 was fine when new battery fitted.
