Author Topic: Snapped subframe walk 16mm bolt. What to do?  (Read 11241 times)
Offline K9
  • VW LifeStyle
« on: October 20, 2016, 12:35:07 pm »
Changed to a walk kit and one off the 16mm stretch bolts snapped when trying to remove them.
What should i do now? one side walk is now secured with the lonk end bolt and one 16mm bolt to the subframe.
anyone else been in this situation before?
« Last Edit: July 02, 2021, 10:14:55 pm by dazza »
Re: Snapped sunframe walk 16mm bolt. What to do?
« Reply #1 on: October 20, 2016, 01:02:12 pm »
Is I snapped one and had to drive it for about 50 miles :-S
Offline K9
  • VW LifeStyle
« Reply #2 on: October 20, 2016, 01:48:25 pm »
i have been driving for like 3 weeks and ni problems. but it's bugging me
Offline Paradox1
  • -Given: 41
« Reply #3 on: October 20, 2016, 04:29:40 pm »
Id complain to whoever supplied the kit.
Think they will need drilling out tbh
Offline K9
  • VW LifeStyle
« Reply #4 on: October 20, 2016, 04:31:25 pm »
It's the oem vw bolt that snapped when trying to remove it
Skickat från min SM-G935F via Tapatalk
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #5 on: October 20, 2016, 07:43:21 pm »
Did it snap in a way you cannot grip it with vise grips to remove the broken bit? You did install the W.A.L.K. with new bolts at all other locations, yes?
You likely need to use an easy-out/bolt extractor to remove the broken bolt if unable to get at it if not protruding outside the subframe. Means drilling a hole in the broken bolt...but first need to make a centered dimple in the end that's broken with a small grinding bit before the final drill bit is used...for being easier. :wink:
« Last Edit: October 20, 2016, 07:48:49 pm by ROH ECHT »
Offline Stupots
  • -Given: 18
« Reply #6 on: October 21, 2016, 08:24:33 am »
When doing my anti lift bushes (I just used TT ones) 4 of the bolts came out fine, one bolt wouldn't come out and the other took about an hour of lubing, undo 1/2 turn, do up 1/4... spray lube... rinse repeat. If you've broken one off you could try buying an Alum bar off of eBay, it dissolves the steel bolt, but not the aluminium. Chances are it's just a few broken threads locking it solid. I know you have broken it, but this will help loosen it up, they are rather tough to simply drill out or use an easy out on. You should be able to see the top of the bolts coming through the sub-frame when looking through the wheel arch, so would be able to apply (and maybe some mild heat) to the end of the bolt and let gravity do it's thing. Don't let it get on the other bolts though, or take them out first!
This vid gives you the rough idea, but it will dissolve a drill bit without touching Aluminium, so it's quite strong stuff :)
Cheers and good luck
Stu
« Last Edit: October 21, 2016, 12:10:44 pm by Stupots »
2006 VW Golf Mk5 Sport TDI 4Motion (140 BKD)
Offline grey golfster
  • -Given: 79
« Reply #7 on: October 21, 2016, 08:45:35 am »
Is that an Alum bar, like those used for shaving?
Is that what he's rubbing on to a heated seized bolt?
Offline Juliand
« Reply #8 on: October 21, 2016, 08:57:17 am »
That was an interesting vid. Shows patience is the key - no bull at a gate there... Like everything - if you have the right kit :congrats:
Offline Stupots
  • -Given: 18
« Reply #9 on: October 21, 2016, 12:10:11 pm »
Yep, one in the same :)
Offline K9
  • VW LifeStyle
« Reply #10 on: October 21, 2016, 04:18:44 pm »
i guess i will have to drill it out  :scared: there is a small head still sticking out like 1cm from the subframe where it snapped.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #11 on: July 02, 2021, 10:14:40 pm »
Opening up an old thread
Went to change the front control arm bushings and one of the stretch bolts snapped on removal.
Vice grips slip off.
Welded a nut on and put the impact gun (electric) on it which did nothing
In the end it snapped again
I could weld a larger nut and really fill it with weld or drill out?
Drilling out would be a pita under the car i suppose i could remove the subframe?
05 | Tornado Red | DSG
  • -Receive: 692
Re: Snapped subframe walk 16mm bolt. What to do?
« Reply #12 on: July 02, 2021, 10:32:41 pm »
Which one sheered?  The yellow arrow one or the red arrow?
The red one is bad news if it means replacing the captive nut in the chassis rail.
If the yellow ones...... I would just get new subframe parts from ebay personally, and run a tap through the threads before fitment, and use anti-seize grease on the new bolts.  I think I paid £50 for the whole lot when my dogbone mount bolt did the same thing.  I couldn't be bothered with welding/drilling/swearing/shouting.
Offline brian_badonde
« Reply #13 on: July 02, 2021, 10:59:51 pm »
Came here to say what Kev said don't even bother trying to drill them, new console section can be had for 25 quid from the breakers.
I sheared mine when I installed my superpro kit. It happens because the tips of the bolts galvanically corrode and seize up on their way back out through the console. You can try corrosion inhibitor on the new bolts for future disassembly but it won't help much as it's chemical reaction. Only sure fire way to avoid it is to wire brush the tips before you remove them.
Sent from my SM-G960U using Tapatalk
  • -Receive: 692
« Reply #14 on: July 02, 2021, 11:37:30 pm »
VAG used to use coated bolts in the good old days when they were diligent about car assembly, but I haven't seen those used since the MK4.  Dealers also used to sell the best anti-seize compound known to man, which was called 'hot bolt paste'.  Can't get either anymore.
I've been using the silver coloured anti-seize grease for years on the MK5 and the chassis/brake/wheel bolts all just plop off with ease  :smiley:
