Author Topic: Audio.  (Read 1459 times)
Offline Tanuie
  • -Given: 36
Audio.
« on: November 05, 2016, 10:28:47 am »
How do you get audio back on to the main dash panel, i have had a new sat nav installed and i seem to be getting everything else come up on the dash except the audio, i cannot use the steering wheel buttons to change the track when the USB is used.
Many thanks.
Offline Trow81
Audio.
« Reply #1 on: November 05, 2016, 11:13:27 am »
U need to set it when the car is not in motion. Put key in turn once so it all lights up. Then go into dash menu and u will see audio option. I had this after installing rns510 for some reason the audio option doesn't appear when driving so u have to select it when stationary then it will show in high line hope this helps
Offline Tanuie
  • -Given: 36
Re: Audio.
« Reply #2 on: November 05, 2016, 12:33:28 pm »
Hi thanks for your reply, I have tried to set it when stopped but no luck.
Offline Tanuie
  • -Given: 36
Re: Audio.
« Reply #3 on: November 06, 2016, 09:45:54 am »
All seems OK now.
