Author Topic: Cheap TTE420 on Awesome's site  (Read 16687 times)
Offline ducman77
  • -Given: 59
Re: Cheap TTE420 on Awesome's site
« Reply #45 on: December 01, 2016, 11:21:22 pm »
400hp @ 11psi (0.8 bar) mate  :smiley:
....The Corrado only had a Quaife diff in it but does nothing with that kind of power  :grin:
Awesome buddy :happy2:
You more than doubled the output of the VR6 :happy2:
Remind me; on the corrado the VR6 output was 174hp or 196hp or something? Can't remember :ashamed:
I am also interested to hear your thoughts on the quaife diff?
As the power climbs on my car I'm considering buying a quaife a peloquin or some such to try and temper the front end?
I would be interested to hear if you think that a worthwhile upgrade or not?
Cheers in advance,
Dave
  • -Receive: 692
« Reply #46 on: December 02, 2016, 10:00:11 am »
Cheers in advance,
Dave
190hp for the Corrado 2.9 and 174hp for the Golf 2.8  :happy2:
The Quaife didn't do a lot in my Corrado but it should work better in the MK5, and I would go for the Wavetrac personally  :happy2:
Does the MK5's traction control brake a spinning wheel?  If so, then yeah a diff would be a good move  :smiley:
I'm saving that for when my gearbox needs a rebuild.  I'm going to put a shorter final drive in it as well because the gearing is way too tall for my tastes  :grin:
« Reply #47 on: December 02, 2016, 03:56:20 pm »
No it doesn't work like that. No "e-diff"on the mk5
  • -Receive: 692
« Reply #48 on: December 02, 2016, 04:39:46 pm »
That is a bit pants.  So it's just engine cut then?  Booooo.
Do you know if the MK6 has it and can be retrofitted?
« Last Edit: December 02, 2016, 04:41:45 pm by Pudding »
Offline d11ps
  • -Given: 47
« Reply #49 on: December 02, 2016, 04:52:04 pm »
Cheers mate, and will do!
Believe it or not, I will be running it with the standard air box and cat back  :grin:
I know that sounds like a waste but peak numbers don't motivate me, it's more the fatter power band I'm after and a turbo that can make the same power as a strung out K04, but at a more relaxed boost pressure, so probs aim for about 360-370hp  :smiley:
I love this idea! Mega stealth mode! Love it :happy2:
Standard appearing Ed30 even when you open the bonnet; Check :happy2:
Big chubby unexpected slug of torque in the midrange; Check :happy2:
No stupid huffing and puffing from the airbox (I've an oversized Ramair and it makes an awful racket - but for some reason I kind of perversely like it :laugh:); Check :happy2:
OEM level of exhaust noise; Check :happy2:
Amen to all of that  :grin:
Here is a previous project where I was told a 2.5" exhaust and factory airbox would be a really bad idea, but was actually a very epic machine indeed!  Really miss it actually, it was bonkers fast  :laugh:   Younger viewers may not recognise the car, but it's a Corrado VR6, and the turbo is a GT35R, which is a superb turbo for reliability, spool and sheer grunt.
I remember following your build thread on vr6oc...absolutely amazing
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #50 on: December 02, 2016, 06:46:34 pm »
Going by the 'farts' emitted from my exhaust when it kicks in I assume it's ignition cut of some sort?
Offline ducman77
  • -Given: 59
« Reply #51 on: December 02, 2016, 07:31:24 pm »
Cheers for the info brother  :smiley: :happy2:
