Author Topic: How much louder does the pre-cat delete make a standard car?  (Read 12017 times)
Offline spwd
  • Hello I'm Steve.
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110133.msg1073872.html#new
« on: December 16, 2016, 03:03:30 pm »
Just wondering if I should get my friendly mechanic to drop the exhaust off and drill the pre- cat out and wondered how louder its going to be?
  • -Receive: 692
Re: How much louder does the pre-cat delete make a standard car?
« Reply #1 on: December 16, 2016, 04:27:19 pm »
Doesn't really make a lot of difference.  It's more going from the standard DP to a 3" one that makes it sound louder.
Make sure he doesn't clog the second cat with crumbs from the first one when he does it!
Offline spwd
  • Hello I'm Steve.
« Reply #2 on: December 16, 2016, 04:51:23 pm »
Thanks bud, and yeah I'll be sure to tell him :happy2:
  • -Receive: 692
« Reply #3 on: December 16, 2016, 04:53:13 pm »
Best to do it upside down on a bench, then all the crumbs fall on the floor and not into the second cat  :smiley:
Offline Duffmeister
« Reply #4 on: December 16, 2016, 06:32:20 pm »
I'm thinking I might do this soon, is it worth the work involved doing it ie does it make any noticeable difference?
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #5 on: December 16, 2016, 06:43:09 pm »
Loads of threads on this - the consensus is that it works nicely with a Stage 1 map. Anything to free up the exhaust is a good thing on a TFSI; that and fuelling are its main bottlenecks.
Stage 2 necessitates a larger downpipe as there's only so much flow the standard downpipe can achieve, regardless of whether the cat(s) have been gutted. I think it's 2.5" diameter or less.
But for a quick, cheap mod to help get the best from a Stage 1 map it's a no-brainer.
Offline spwd
  • Hello I'm Steve.
« Reply #6 on: December 16, 2016, 06:46:34 pm »
I've been told the cats are the biggest bottlenecks in the system and it doesn't look a hard job, if you have the room to get the downpipe off.
This is one of the cheapest and easiest mods that people do on a Toyota MR2turbo and it sounds like it helps on the golfs, but I'm sure someone more cleverer will be along soon to give you better info, obviously a replacement downpipe is better but I've not got £300 + to spend on that so this is next best thing.
Offline spwd
  • Hello I'm Steve.
« Reply #7 on: December 16, 2016, 06:52:16 pm »
, looks pretty easy to me :happy2:
Offline Duffmeister
« Reply #8 on: December 16, 2016, 06:54:27 pm »
If I go full decat 3" down pipe will it pass an mot?
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #9 on: December 16, 2016, 06:59:32 pm »
Not with a decat.
Offline Norfolk Ollie
« Reply #10 on: December 16, 2016, 07:03:11 pm »
Hi SPWD- I ummed and arred about this too but had it done in the end and all I can see are gains not negatives. Unknowingly I had a cheap after market DP on mine when it went to R-tech for a stage 1 and it hindered the power  before and after the re-map. Since then I had the cam chain tensioner done, pick up pipe service, sump off and cleaned, millers nanodrive oil and while they were at it, got AKS to fit an oem DP with the pre cat deleted. All of these things have really sorted the old girl out and I can feel a real difference now. The car used to lurch a bit on pull away but that is now remedied and when you give it the beans the car is more responsive. It isn't really any louder as such but you get a nice burble if you blip the throttle. I'd get it done mate! Cheers, Ollie.
Offline spwd
  • Hello I'm Steve.
« Reply #11 on: December 16, 2016, 10:45:16 pm »
Cheers Ollie :happy2:
Offline bonelorry
  • -Given: 72
  • -Receive: 44
« Reply #12 on: December 17, 2016, 03:28:38 pm »
I noticed no noticeable increase in noise from the Exhaust after removing the Pre-Cat on my Edition 30, It did make 315BHP and 330LB/FT of Torque at R-Tech after the Stage 1 Re-Map though so was a very worthwhile upgrade.
I do recall noticing a Minor increase in Throttle response and less Turbo lag too but I only drove the car for a few days before getting it mapped.
Offline spwd
  • Hello I'm Steve.
« Reply #13 on: December 17, 2016, 04:25:37 pm »
Thanks for the info bonelorry  :happy2:
Offline shoaybmakda
  • -Receive: 54
« Reply #14 on: December 18, 2016, 02:21:40 pm »
No extra noise here too - a few extra pops from DSG shifts but not anything someone would think was from a 1.4 Vauxhall nova with a 6" back box system lol
As others have said more positives and no negatives to report. Get it done  :happy2:
