Author Topic: New Front Tyres - Thoughts Please  (Read 3739 times)
Offline Juliand
« on: February 06, 2017, 03:34:04 pm »
Sorry, probably been done loads....
My GTI 2005 needs new fronts. The previous owner had put Eagle F1's on the rear, but the front has Pirelli P600's, and need replacing, so my initial thought is to match up with the rears and go for Eagle F1's.
Is this the best thing to do?? The rears have loads of tread remaining. Car has done 36,000 miles
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: New Front Tyres - Thoughts Please
« Reply #1 on: February 06, 2017, 03:45:57 pm »
I am in the exact same boat. I fit Eagle F1's all round but one of my fronts has a nail in it and a broken side wall.
Im thinking of changing both fronts to Michelin PS4's but not sure how that would work with Goodyears Eagle F1's on the back
« Reply #2 on: February 06, 2017, 03:49:56 pm »
All depends on your budget really
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: February 06, 2017, 04:00:17 pm »
Will Michelin PS4s on front have some sort of handling inconsistancy if the rears are Goodyear F1 Assy 3's?
Offline neiller
  • -Given: 32
« Reply #4 on: February 06, 2017, 04:28:44 pm »
Im in a similar situation at the minute im running continental contisport contact 5 i was looking at uniroyal rainsport 3s but havent heard any1s opinion on them amazon are doing a dgood deal on them atm
  • -Receive: 692
« Reply #5 on: February 06, 2017, 04:52:18 pm »
Nah, it'll be fine.  At that level the differences aren't huge, although the PS4 is noticeably better than the F1 in most circumstances.
If you'd said 'I find ditch for you sunny funners' at the front, with F1s at the back, different story!
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #6 on: February 06, 2017, 04:57:22 pm »
sold.
Cheapest fitted I found is £101.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #7 on: February 07, 2017, 06:11:37 am »
Will be fine, that's what I have now until the rears go and i swap them to  PS4s too
Offline unzippy
« Reply #8 on: February 07, 2017, 09:09:02 am »
Blimey, you have worn out P600s!
Good work :grin:
Offline Juliand
« Reply #9 on: February 07, 2017, 10:05:37 am »
Just checked the prices on the Pirelli p6000 - they are quite pricey £140
Found PS4's at £90 at F1 Autocentre, if ordered online
Got MOT tomorrow, was going to top up pressures a smidge, but hesitating in case I cant get the pressure warning light back off, once topped up, doh..... Anyone had any problems with TPS light???   Sod's law etc
  • -Receive: 692
« Reply #10 on: February 07, 2017, 10:09:53 am »
What TPS light?   Didn't know MK5s had tyre pressure warnings!  Or do you mean the button on by the gearstick for resetting the rolling circumference?
£140 for P6000s?  You're kidding?!  They are quite literally the worst tyre I've ever used in the wet, and that comes from someone who used Yokohama A509s! Not bad in the dry though.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #11 on: February 07, 2017, 10:26:38 am »
Mk5s have a passive tyre pressure monitoring system that controls wheel rotation difference between wheels. If all deflate at the same time I'm not sure it will warn anything.
The button only resets the system if you press it just after turning on the ignition. You can't do it after the car has rolled.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #12 on: February 07, 2017, 10:51:28 am »
Unless switch is broke or there's a fault with an ABS sensor etc. it'll be fine
Offline MrVW1589
  • Eat Sleep VW
« Reply #13 on: February 07, 2017, 02:11:23 pm »
I got 2 new front Goodyear eagles for my zolders costing me £200 fitted from ATS local to me, which I didn't think too bad and have served me well since, good in wet and dry!!
Offline bonelorry
  • -Given: 72
  • -Receive: 44
« Reply #14 on: February 07, 2017, 02:22:48 pm »
£140 for P6000s?  You're kidding?!  They are quite literally the worst tyre I've ever used in the wet.
These where original fitment on Peugeot 306 Rallyes, Absolutely lethal Tyres the P6000's! I replaced mine with the old rotational Goodyear F1 GSD3's back in 2008.
