Author Topic: Thoughts on my first week of ED30 Ownership  (Read 5945 times)
Offline neilw
« on: February 22, 2017, 12:42:15 pm »
I've had my Tornado Red GTI ED30 just under a week now and am starting to get to know the car. I thought I'd share my initial thoughts on the car. My previous cars were a Z4 Coupe and A4 TDI 130
- The handling feels really good, it gives me loads of confidence in the corners
- I need to stop driving it like my old A4 Tdi, and use the revs, Otherwise, it doesn't feel that fast
- The MFD2 Headunit sounds terrible, this will be my first upgrade
- Don't have the computer set to MPG
- I really like the Mirrors down, Puddle lights, Coming home lights
It feels like a big grown up version of my 6n2 Polo GTi I owned 6-7 years ago
At the weekend I'm putting in fresh Oil, Oil Filter, Pollen Filter, Fuel Filter and replacing the Cam Follower. The weekend after that with the help of a mate who's a tech at an independent VAG specialist we're going to change the Cambelt, Waterpump and put a new thermostat in, and chuck a new PCV valve on.
I need to try and find out what build number I have as I have no plaques
Then after swapping out the headunit I'll put a DV+ on there. I then plan to keep the car standard for a year or so and then think about an exhaust and some lowering springs and a remap.
« Last Edit: February 22, 2017, 01:11:36 pm by neilw »
Edition30 #0002 R-Tech Stage2
Offline Paradox1
  • -Given: 41
Re: Thoughts on my first week of ED30 Ownership
« Reply #1 on: February 22, 2017, 12:58:34 pm »
Dont forget the cam follower too!
Offline neilw
« Reply #2 on: February 22, 2017, 01:10:03 pm »
I've got one, it's going in on Saturday :)
« Reply #3 on: February 22, 2017, 01:34:34 pm »
The Ed30 does need to be reved thats for sure. It only come on song over 3000RPM
  • -Receive: 692
« Reply #4 on: February 22, 2017, 01:51:43 pm »
And if it's still standard, 230hp isn't much either.
Offline grey golfster
  • -Given: 79
« Reply #5 on: February 22, 2017, 01:56:05 pm »
The full contact details for the man you need at VW UK are buried in the Edition 30 register pages. They have been updated fairly recently, so try p 45 or so...that thread can be a pita to search, but the info is all there.
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
« Reply #6 on: February 22, 2017, 04:17:19 pm »
Remap  :evilgrin:
Was the best thing I've done to mine by far. It transforms the car. Left rtech with an extra 80bhp from stock.
Stage "1.5" ED30 [330BHP] Rtech
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #7 on: February 22, 2017, 06:41:58 pm »
All Ed. 30 should be remapped.  :evilgrin:  Waste of engine on stock file.
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #8 on: February 22, 2017, 07:36:16 pm »
It's pretty much accepted knowledge that the ed30 was 'detuned' so it didn't step on the toes of the flagship R32.
How much boost do they run standard? Can't be much more than 9psi or so?
Get a decent downpipe and map and it'll come alive!
Offline neilw
« Reply #9 on: February 22, 2017, 07:55:36 pm »
Cheers guys sounds like good stuff!
Do you get any issues with torque steer when running around 300bhp? The car needs to be usable everyday on commutes  :smiley:
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #10 on: February 22, 2017, 08:08:37 pm »
The mk5 chassis doesn't suffer at all badly from torque steer. I'm running about 350lb/ft and it really isn't an issue.
Compared to an Astra VXR my mate had it's leagues above. That was only Stage 1, so around 270/270 and it was terrible for torque steer.
What you might struggle with is traction itself. Once you get up towards 330-340lb/ft with mods like an uprated fuel pump and downpipe, and Stage 2/2+ map, it can be tough to get the power down in the lower gears.
But if you get a good progressive map, such as R-Tech you'll have a better chance of keeping traction. At Stage 1 levels of torque (300-320lb/ft) you shouldn't struggle anyway.
Offline spesh
« Reply #11 on: February 22, 2017, 08:54:29 pm »
how does the stock clutch deal with stage 1? I've got an eddy but its just tipped over 100k so I'm concerned that a remap will see off the clutch quite quickly
Offline neilw
« Reply #12 on: February 22, 2017, 09:08:42 pm »
Thanks, I'm not going to be going crazy with mods. So I should be fine. Map, Exhaust and intake is probably all I'll do power wise, nothing for a year or so tho until I'm with a mod friendly insurer. I don't want to get to the point I need fuel pumps, and bigger brakes ect. R-Tech looks good
Here she is anyways
« Last Edit: February 22, 2017, 09:21:21 pm by neilw »
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #13 on: February 22, 2017, 11:38:27 pm »
Stock maps does 1.2 bar of peak boost and 0.8 bar of stable boost. Pretty low boost if you ask me. :smiley:
Enough for 270 BHP with a TBE, IC and HPFP so the stock hardware chokes the engine. :wink:
« Reply #14 on: February 22, 2017, 11:40:36 pm »
Which is bollocks because a stock ed30 is quicker than an R32....except launching.
