Author Topic: Electric window switch failure  (Read 1105 times)
Offline IOMAL
  • -Given: 19
« on: April 18, 2017, 08:50:12 pm »
the elec window won't go down from the passenger side but does go down from drivers side controls ,so it is working obviously a break in the wire ,where is the best place to start ,from the switch to the window or could the break be in the door gaitor?
Offline doylebros
  • -Receive: 310
Re: Electric window switch failure
« Reply #1 on: April 18, 2017, 10:11:51 pm »
Drivers side door wiring would be my starting point but you could check the switches with VCDS in output testes without any disassembly.
