Author Topic: Highline coding  (Read 5869 times)
Offline oisinc
Highline coding
« on: June 12, 2017, 12:16:54 am »
Hey all..
What's the software needed to code 2008+ cars?
Trying to see if I can get one of my cars done here in Ireland.
Have a fella who can code but need to make sure we have the right gear to do it.
Any help appreciated..
So far one of the forum "gurus" is being his usual arsey self..
Sent from my ONEPLUS A3003 using Tapatalk
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Highline coding
« Reply #1 on: June 12, 2017, 01:36:02 am »
The problem with gurus are they won't give out FREE info as they spent years and a lot of money to get this info so not happy about giving it out  :signLOL:
Offline ady-uk
  • -Given: 19
  • -Receive: 24
Re: Highline coding
« Reply #2 on: June 12, 2017, 08:16:29 am »
That's going to work well.....   :rolleye:
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Highline coding
« Reply #3 on: June 12, 2017, 08:27:03 am »
As r5gtt says, no ones going to give that info out. Better off just sending both current and new cluster to someone who can do it and they will code and send it back
Sent from my SM-G955F using Tapatalk
Offline oisinc
Re: Highline coding
« Reply #4 on: June 12, 2017, 11:46:19 am »
It's cool.. found out the info I needed.. all it was info.. no big deal. It's not classified info...
Offline SI-R32
  • -Receive: 126
Re: Highline coding
« Reply #5 on: June 12, 2017, 01:31:32 pm »
you're totally right its not classified info, most people use AVDI from Abrites which can cost in the region of a grand, if your speedo hasn't got any mileage in it or has been reset to zero you might be able to use VAS 5054A with an online Geko connection to VW which you can pay for by the hour I believe.
But the best news for us all is the fact there are some leads coming out of china that sound remarkably like "AVDI" and can be relativity cheap ish 150 to 300 for depending on which software you want. if you want links to it please ask via PVT message and I'll point you in the right direction.
You can program the key chip up and do all sorts with it, I'll be learning all about this over the coming months as I've just got the software and will be learning what to do with the aid of the AVDI German forum.
all the immobiliser chips and the software are available from Aliexpress.
one of the best things about it, it has an MK60EC1 coding helper built in which is worth its weight in gold to all the people that want to retro fit PLA 1/1.5/2 to older cars needing there brake unit upgraded.
« Last Edit: June 12, 2017, 02:08:07 pm by SI-R32 »
Offline oisinc
Re: Highline coding
« Reply #6 on: June 12, 2017, 01:33:46 pm »
That's what I'm talking about!
A helpful forum user! :) :)
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Highline coding
« Reply #7 on: June 12, 2017, 01:53:43 pm »
I thought there was soldering involved as well?
Pretty sure Eddie desoldered something off my clusters once. He definetely had the rear case opened and had some wires going to some pins
Offline SI-R32
  • -Receive: 126
Re: Highline coding
« Reply #8 on: June 12, 2017, 02:05:43 pm »
I believe there is yes but all this info is either on forums or instructions somewhere, especially for a range of cars that ended in 2009, plus you do need the software.
plus the OP only said highline coding is this is only from a midline (all red) I'm sure it's not rocket science, when Kalu did my white one he was only gone a matter of minutes so if it does require soldering or eeprom reading or anything then its just finding the info needed.
It's just a case of slowly learning what to do, they all started somewhere.
just found this, a nice little read
http://www.vwwatercooled.com.au/forums/f97/tiguan-cluster-retrofit-red-mfd-white-mfd-colour-premium-mfd-88721.html
« Last Edit: June 12, 2017, 02:14:43 pm by SI-R32 »
Offline oisinc
Re: Highline coding
« Reply #9 on: June 12, 2017, 07:55:45 pm »
I like your style buddy..
I wasn't looking for a how to guide but just what software was required...
Can't understand how some people want to defend that kind of info.. it's not like it is going to be stolen from them.. it's out in the marketplace there for the taking(buying).
Just wanted to make sure the coder dude over here was fully kitted up and could do the job..
Anyway best of luck with your learning curve and keep us all informed..
Offline ducman77
  • -Given: 59
Re: Highline coding
« Reply #10 on: June 13, 2017, 08:33:24 am »
@SI-R32 thank you for your helpful and informative posts - very much appreciated by another fellow enthusiast :happy2: :happy2:
Offline mkmg76
Re: Highline coding
« Reply #11 on: June 14, 2017, 09:29:57 am »
+1  :happy2:
This is how forums are supposed to work, information shared between enthusiasts. People guarding this info like their lives depends on it seems a bit odd since they had to learn it from somewhere. It's not like they invented the bloody thing.
Good on you for sharing @SI-R32  :congrats:
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 79
Re: Highline coding
« Reply #12 on: June 14, 2017, 10:01:00 am »
+2
Agreed and well said @mkmg76
Offline dronners
Re: Highline coding
« Reply #13 on: June 14, 2017, 03:32:35 pm »
some peoples livelihoods do depend on it. i'm sure its the primary source of income for some people.  not saying information shouldn't be shared around  but i could understand how some people might want to guard it carefully.   it'd be a bit like coca cola telling the whole world there recipe. wouldnt do them much good would it
Offline SI-R32
  • -Receive: 126
Re: Highline coding
« Reply #14 on: June 14, 2017, 03:46:41 pm »
Nothing secret is being shared here, all this info Is available if you search the Web and are possibly willing buy a few products.
People can still make money off of what they want but if your willing to try and give anything a go then the info should be there for people, that after all is why tons of questions are answered on here Daily, this is what I like about every forum I use.
Besides there are forums for vcds, vag can pro, avdi, plus many other general forums that give out answers to questions all in forum sprit, hardy breaking into cia nsa territory here lol.
