September 22, 2026, 07:43:56 am
All Things Mk5
Mk5 General Area
Jingling/Tinkling noise on spool.
Topic: Jingling/Tinkling noise on spool. (Read 2860 times)
djhorace
Always Involved
-Given: 1
-Receive: 6
February 04, 2010, 02:26:59 pm »
As per title, does anyone else have this?
There is a thread over on SCN here -
http://www.seatcupra.net/forums/showthread.php?t=244058
djhorace
Always Involved
-Given: 1
-Receive: 6
Re: Jingling/Tinkling noise on spool.
Reply #1 on:
February 06, 2010, 11:56:39 am »
Nobody else got this?
micky 32
Always Involved
-Given: 5
-Receive: 4
Reply #2 on:
February 07, 2010, 06:14:53 pm »
I have a KO4 on my vRS and no i don't have that noise.
2008 Octavia vRS K04'd , Forge twintercooler, Evoms, Autotech uprated pump, full Milltek exhaust 324bhp on JKM's rollers ;-)
Poverty
Just look at my post count
-Given: 36
-Receive: 21
Reply #3 on:
February 07, 2010, 06:15:44 pm »
http://www.mk5golfgti.co.uk/forum/index.php?topic=11498.0
djhorace
Always Involved
-Given: 1
-Receive: 6
Reply #4 on:
February 07, 2010, 10:59:25 pm »
Not the same noise by the sound of it mate.
djhorace
Always Involved
-Given: 1
-Receive: 6
Reply #5 on:
February 09, 2010, 03:13:01 pm »
Just spoke to someone who reckons this could be the fuel truss sensor on the inlet manifold. The way he explained it, it goes away when the stock code is on the car which is exactly what happened to mine when I stripped it back last year to sell it.
Hurdy
-Given: 52
-Receive: 137
Reply #6 on:
February 09, 2010, 04:43:27 pm »
I changed mine too, but for a different reason and to something different rather than OEM
micky 32
Always Involved
-Given: 5
-Receive: 4
Reply #7 on:
February 09, 2010, 06:56:33 pm »
On the inlet manifold? I thought that was air inlet temp sensor.. Hurdy what have you in place?
Janner_Sy
-Given: 62
-Receive: 113
Reply #8 on:
February 09, 2010, 06:58:39 pm »
yeah as did i, that is the MAP sensor(thrust sensor)
x2 what have you replaced it with hurdy
micky 32
Always Involved
-Given: 5
-Receive: 4
Reply #9 on:
February 09, 2010, 07:03:35 pm »
I think the map sensor is the one on the plastic pipe going to the throttle body.
Hurdy
-Given: 52
-Receive: 137
Reply #10 on:
February 10, 2010, 12:39:00 am »
Quote from: vRSy on February 09, 2010, 06:58:39 pm
OEM part is in front of me now.
06D 130 767C by KLN stamped on the side.
Still working through logs and set up to see if changing it helps.
It is the pressure limiting valve in the pic below.
http://daz.co/media/hh199/tbuccini/130bar_failure_Hypo.jpg[/img]"]
JettiGLI
Can't Read PM's Yet!
-Given: 1
-Receive: 0
Reply #11 on:
July 02, 2010, 09:09:29 pm »
Did anyone solved the partial throttle noise issue? Does the RS4 Fuel return valve solves the problem?
All Things Mk5
Mk5 General Area
