Author Topic: Fitting rns510 radio mk5 gti  (Read 8466 times)
Offline Dannyboi#722
  • My Ride: GOLF GTI EDITION 30 TTE480 BHP 446 & 443FT*LB FORGED (Mapped by R-Tech)
« on: July 26, 2017, 04:27:33 pm »
Retro fitting rns510 radio to my mk5 gti 57 plate wondering weather somebody could tell me if it's going to cause a battery drainage problems? beacause after read a couple of things on here so would really appreciate it, If anybody could point message in the right direction thanks
« Last Edit: July 26, 2017, 04:34:49 pm by Dannyboi#722 »
Offline Christiank
  • -Receive: 39
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110924.0.html
Re: Fitting rns510 radio mk5 gti
« Reply #1 on: July 26, 2017, 08:54:39 pm »
When you say 57 plate. Does this mean the car is from 2005 / 7 month?
If yes I'm pretty sure you need a new canbus gateway.
MK5 TDI 2.0 MY2005 - FULL OF RETROFITS:
MK6 dashboard - BCM converted - MK7 cruise control MFSW - PLA 2.0 - 3D instrument cluster - Discover Media 2 - Highline TPMS - 10ch Dynaudio system - KESSY with start button
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #2 on: July 26, 2017, 09:58:05 pm »
57 is late 2007.
I had an RCD510DAB fitted to my 07 (early 2007) and didn't need to change it.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: July 26, 2017, 10:11:24 pm »
Get someone with vcds to scan it to tell u the part number or fit the rns and if you get battery drain then you know it needs changing
Sent from my SM-G955F using Tapatalk
Offline Christiank
  • -Receive: 39
« Reply #4 on: July 26, 2017, 10:46:45 pm »
If your car is a 2007 it won't need changing.
« Reply #5 on: July 27, 2017, 07:16:06 am »
Thanks guys really appreciate your help.
  • -Receive: 692
« Reply #6 on: July 27, 2017, 09:21:16 am »
It also depends on the revision of RNS510.  The later ones can have the battery drain fix done internally with a software tweak.  Mine is a version 'Q' with the tweak, and no draining issues.  Left it in Gatwick for 2 weeks and it fired right up  :happy2:
Offline Ripstop
« Reply #7 on: July 30, 2017, 10:34:31 am »
Take a look at these pages and see what Canbus you are going to need. The later unmodified revisions of RNS510 firmware above 2660 will give you a battery drain issue if your can-bus is K or earlier. The critical change over year was 2007 so just do a little checking against what you have.
https://www.my-gti.com/1101/upgrading-2nd-generation-radios-rcd-300-rcd-500-to-3rd-generation-rcd-210-rcd-310-rns-310-rcd-510-power-drain-issue
https://www.my-gti.com/3983/volkswagen-rns-510-hardware-and-software-firmware-versions
 As @Pudding said some enterprising people have modified the firmware to code out the issue but you will need a little bit of research. Some revisions of canbus L will work but its hit and miss due to the specific L revision. Anything above this *should* be fine but there are more expert people on here than me who can confirm  :smiley:
Rip.
Stage 1 2007 Black Eddy  #1000 - VCDS Hex+Can (Novice coder). H&R springs, newish Bilstein B4's. Gen 3 Steering rack, Helix organic.  The car is *always* work in progress fixing and upgrading things.
  • -Receive: 692
« Reply #8 on: July 31, 2017, 04:03:51 pm »
Aye.  I bought an updated CANBUS and that was more hassle than it was worth, so refitted the original box.  Bought a newer 510 off the bay and the seller asked if I wanted the internal BD tweak done, which would remove the need for a gateway update.  Yeah, why not, go ahead!
I can't remember the ebay shop, but from his English I'm guessing East European, and obviously a ton of 510s available over there due to the terrible driving.
