Author Topic: Revo Stage 2 Gone Back To Stock  (Read 7482 times)
Offline GTIJohnEd30
« on: August 02, 2017, 01:47:01 pm »
Just a quick one people, my stage 2 revo map had stopped working! I've had it checked and the settings are on the ECU so I've had to look elsewhere to find what's up, now I've found a fault on the diagnostic machine with the Fuel Pressure Sensor! And the Camshaft sensor I believe it is, Has anyone else had this or had this sort of problem before? As my local vagtech dealer said it's more than likely the fuel pressure sensor which has reverted the map back to stock!
Offline Greigzy
Re: Revo Stage 2 Gone Back To Stock
« Reply #1 on: August 02, 2017, 01:50:44 pm »
Have you had the battery disconnected lately?
Revo maps go back to their basic settings if the battery has been disconnected. It can be put back to the required setting with a Revo SPS or by going back to the Revo dealer if this is the case
Offline GTIJohnEd30
« Reply #2 on: August 02, 2017, 07:43:03 pm »
No mate battery hasn't been out, revo think it may be the fuel pressure sensor which I'm changing tomorrow morning! Fingers crossed it's that
  • -Receive: 692
« Reply #3 on: August 03, 2017, 10:13:39 am »
Yeah if the ECU doesn't know the fuel pressure, you'll be severely torque limited.  If it's the HPFP sensor that's cracked in half (common problem), you'll be budgeting for a new pump if it's OEM.  Approx £170ish on ebay or £250ish at VW.
Offline GTIJohnEd30
« Reply #4 on: August 03, 2017, 10:45:46 am »
Update time, replaced the fuel pressure sensor, took the car out and it went back to its normal brutal self! Then 10 mins later it went back again to stock! Took it back to the garage where My mate has the diagnostic machine and it came up again with the fuel pressure sensor! So he again cleared the codes from the ECU and again it rips like a stage 2 should! So.... spoke to Vagtech and they seem to think it could be a possible wiring issue which they are going to look into on Tuesday for me! But not only that they said as the previous owner has put an updated fuel pump on it and not gone and got stage 2+ done it could of been running too rich for the amount of time it's and the new uprated fuel pump too! hopefully Tuesday this will be all figured out and fixed lol
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #5 on: August 03, 2017, 11:17:02 am »
It won't run rich on a Stage 2 map because of an uprated pump. The pump will only supply as much fuel as the ECU requests. If anything, having an uprated pump with a Stage 2 map is more reliable than with a standard pump, ie you won't get fuel cuts like you sometimes can with Stage 2 and a standard pump.
Good luck getting it sorted anyway bud - it's probably a sensor causing the issues.
« Last Edit: August 03, 2017, 11:21:11 am by AJP »
Offline GTIJohnEd30
« Reply #6 on: August 03, 2017, 03:50:35 pm »
Cheers mate! Hopefully it'll be some sort of wiring issue and it'll be fixed Thursday
Offline GTIJohnEd30
« Reply #7 on: August 08, 2017, 02:15:59 pm »
Update... Vagtech have plugged it in and it's came up with the System too lean off idle P2177 upper limit reached code! So first port of call I've ben told to change the PCV valve so that's getting done now! Hopefully that'll be it and my Stage 2 will stay Stage 2 lol
Offline GTIJohnEd30
« Reply #8 on: October 29, 2017, 09:58:03 pm »
Just an update on this situation.. so after spending quite a bit of money upgrading the fuel system and other numerous parts trying to sort out this problem it was finally sorted and it was the god dam bloody fuel rail pressure sensor which I changed BUT VW/TPS decides to give me the bloody ko3 turbo 139bar one not the Ko4 200bar one! No problems since and it’s running fine now
« Reply #9 on: October 30, 2017, 01:54:15 am »
good to see you got it sorted thou
Offline illyun
« Reply #10 on: December 24, 2017, 08:49:05 pm »
Well, I am back in Blighty for good now (arrived in August this year) and my Edition 30 had the same issue back in 2009.  I never resolved it and its been in storage ever since - I will be taking it out next summer and getting it sorted.  I could never sell that Edition 30, bought new in 2007 and only driven for 2 years.  It is still like new.
Can't wait till the summer!   :driver:
Offline illyun
« Reply #11 on: December 24, 2017, 08:56:27 pm »
On another note, its so great to see some of the old-timers like @Hedge, @Hurdy, @Deako and @RedRobin still on here  :happy2:  Apologies if I have missed anyone out... it was a long time ago!
« Reply #12 on: December 24, 2017, 11:10:01 pm »
Hi illyun!
Good to know you are well and alive and kicking!
My red chariot Mk5 is still going strong (on Revo Stage 2) and had a deep maintenance done by JKM last July just to keep her well maintained and running. Coming up to 127,000 miles of fun!
I'm not often here but just occasionally when someone tags me.
Offline illyun
« Reply #13 on: December 25, 2017, 12:23:35 am »
Hi illyun!
My red chariot Mk5 is still going strong (on Revo Stage 2) and had a deep maintenance done by JKM las July just to keep her well maintained and running. Coming up to 127,000 miles of fun!
Hi Robin!  Great to hear from you...  Are JKM as good as ever?  I will probably be taking the car to them to get a LOT done:
1. Full Service including things like spark plugs etc
2. DSG Gear Oil change
3. Lean fuel issue sorted - I believe that after 8 years - wow has it really been that long?! - we have a limited number of potential solutions from what I have read.
4. Will probably have to replace the brand new Michelin Pilot Sport 2's that I had fitted in 2009 and never used  :fighting:
5. Engine Cam chain and tensioner.
etc... its going to cost a bomb I'm sure.  It has been stored in a heated garage with battery conditioner fitted since then at £100 a month, so thats around £8000+ spent on storage since 2010    :rolleye:
« Last Edit: December 25, 2017, 12:25:23 am by illyun »
Offline v4rley
  • -Receive: 104
« Reply #14 on: December 25, 2017, 08:01:58 am »
Wow  :laugh:
Going to need it’s first MOT too  :grin:
