Author Topic: Fitting door lights  (Read 9698 times)
Offline Ant b
Fitting door lights
« on: November 20, 2017, 08:53:50 pm »
Hello I’m trying to fit door warning lights onto my 05 gti,
I’m rubbish with electrics and I no you can use the pins but I don’t have vagcom and don’t really wanna fit them replace the door card and then when I get them coaded find they don’t work,plus I don’t no what pins to use.
So I was hoping to find the door plunger and go from there but I carnt find it,and I don’t really wanna run a wire from inside through the multi plug.
If someone could kindly tell me exactly what pins I need so I no when it’s all back togeather it will work that would be grate.
red mk5 golf gti ks05 fak,ram air intake,3” downpipe/decat,dv+,bcs rev ll exhaust stage 1 remap.coilovers,whiteline rarb and depo projectors,
Edition 30 front splitter,r32/gti rear,r32 side skirts
Soon to be r tech stage 2
Offline Ant b
Re: Fitting door lights
« Reply #1 on: November 20, 2017, 09:26:53 pm »
Offline doylebros
  • -Receive: 310
Offline Ant b
« Reply #3 on: November 21, 2017, 10:33:26 am »
I’ve read all that,but that’s on a gen 3 07 mines an 05 and none of the controller part numbers match mine,plus I’m still not sure
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #4 on: November 21, 2017, 10:52:35 am »
your modules are version K so they are Gen 2.
You need to put the positive wire from the door module into pin 1, and then connect the negative wire to a ground.
Best to tap into the ground from the fuel cap
Remember: The part number of your door modules is not the one on the black box, but the one on the sticker on the silver motor ending in 701 K
Offline Ant b
« Reply #5 on: November 21, 2017, 11:00:01 am »
Perfect thank you,for the ground do I tap into pin 4 as some are saying
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #6 on: November 21, 2017, 01:50:29 pm »
not sure on Pin 4 mate. But I tapped into the fuel cap switch
Offline Ant b
« Reply #7 on: November 21, 2017, 03:47:59 pm »
@RetroRaz
I hope I’ve done it right,I put the red into pin 1 and extended the wire so it reaches,and I used the brownish wire on the fuel flap wires for earth,below is the plug now.
I assume passenger side is the same but we’re is the earth
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #8 on: November 21, 2017, 04:54:18 pm »
@RetroRaz
That looks right.
Not sure where the ground is on passenger side.
Sent from my SM-G955F using Tapatalk
Offline Ant b
« Reply #9 on: November 21, 2017, 05:32:21 pm »
Hopully it will work when all coded in,we’re did you ground on the passenger side
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #10 on: November 21, 2017, 05:42:33 pm »
on my current golf, i have gen 3 door modules so I used an empty pin slot (cant remember the number)
on the older golfs I had I had gen 1 and honestly I cant remember at all where I grounded it. Might have been a window switch ground or an empty pin on the connecter.
Can someone else confirm where they grounded theirs please?
Offline Christiank
  • -Receive: 39
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110924.0.html
« Reply #11 on: November 21, 2017, 07:46:57 pm »
Gen 1-2 use : +12v in PIN 1 and ground from PIN 2 or 4.
Gen 3 use : +12V PIN 18 and ground from PIN 19
Look at the motor partnumber(not the black electronik box) , Gen 3 has revision N, M and Q.
MK5 TDI 2.0 MY2005 - FULL OF RETROFITS:
MK6 dashboard - BCM converted - MK7 cruise control MFSW - PLA 2.0 - 3D instrument cluster - Discover Media 2 - Highline TPMS - 10ch Dynaudio system - KESSY with start button
Offline The Red Warrior
« Reply #12 on: November 22, 2017, 07:37:46 am »
@Ant b  Yes, as Christiank says, you can use pin slot 2 or 4 for your ground on the passenger side door. I used 4 as you saw in my photo.
No need to reply to my reply to your PM as I did a bit of searching and found the thread you were referring to and in turn this one.
Looks like you've got it all sorted now.  :happy2:
Offline Ant b
« Reply #13 on: December 04, 2017, 03:30:58 pm »
I’ve had it coded today and the drivers side works fine,but the passenger side wasn’t fitted,I’ve now fitted it but still dosent work any ideas,do you need to code each side in
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #14 on: December 04, 2017, 05:36:21 pm »
Yes , add 64 to the current coding number on both sides door modules
