September 03, 2026, 04:40:59 pm
All Things Mk5
Mk5 General Area
Need a bolt part number
Topic: Need a bolt part number (Read 5140 times)
Shoduchi
Just look at my post count
-Given: 220
-Receive: 430
My Ride:
February 01, 2018, 01:50:27 pm »
Anyone know the part number of this bolt? Or where can I source one if VW doesn't sells them?
It was removed from my DSG but was too stuck to be removed without suffering any damage. I've searched ETKA and online but I haven't found any just like it.
It's a M8x60 mm, triple square.
Edit: Corrected the size of the bolt.
Last Edit: February 01, 2018, 04:46:23 pm by Shoduchi
Silver Reflex Mk5 Golf GT Sport
.:R-Line
1.9 TDI 105@171PS 5 Doors
Candy White Mk5 Golf GTI Edition 30 DSG 230@409PS 3 Doors
Dan_FR
-Given: 132
-Receive: 189
wait...what?
Re: Need a bolt part number
Reply #1 on:
February 01, 2018, 02:08:04 pm »
What part of the DSG was it removed from exactly? I'd be surprised if one cannot be found & bought from VW
TFSI... Revo Stage 2+... . WMI.... VCDS HEX + CAN, MPPS, VAG Commander & VAG tacho - South Wales
Dan_FR
-Given: 132
-Receive: 189
wait...what?
Reply #2 on:
February 01, 2018, 02:15:42 pm »
Found the ones VW list that are either 50mm, 55mm, 65mm or 70mm. No 60mm. How odd
55mm is N91030402
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/shouldered-hex-triple-square-bolt-m12x55-priced-each/n91030402/
65mm is N91060202
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/hex-head-12pt-bolt-m12x65-priced-each/n91060202/
It's referred to as a 'multi-point socket head bolt with collar' or a Shouldered Hex / Triple Square Bolt
Last Edit: February 01, 2018, 02:21:37 pm by Dan_FR
Shoduchi
-Given: 220
-Receive: 430
My Ride:
Reply #3 on:
February 01, 2018, 02:27:02 pm »
I don't know if the name is the same in English. We call it cloche, it's the case that is over the flywheel and is connected with the DSG itselft. There are 18 of these bolts. The listed bolts are all shouldered hex bolts with triple square. I could find one with those dimensions on manual gearboxes: N10690801.
The closer looking bolt that I've found using the ECS Tuning site was the N91042802.
.:R-Line
Dan_FR
-Given: 132
-Receive: 189
wait...what?
Reply #4 on:
February 01, 2018, 02:54:12 pm »
Ah, I've just looked at the picture again and realised there's no hex head on it, didn't notice that on first glance on my phone.
No idea what a cloche is unfortunately, but that last part number looks bang on?
N91042802 is a M12 * 1.25 * 60
Shoduchi
-Given: 220
-Receive: 430
My Ride:
Reply #5 on:
February 01, 2018, 03:06:10 pm »
I've just looked online better, cloche is the clutch housing. Simple.
The bolt that I found very similar doesn't have threads up to the head. That's the difference. Not sure if the threads are needed for my application. My bolt just screws in the tip.
.:R-Line
coolhandluke
Always Involved
-Given: 28
-Receive: 11
Reply #6 on:
February 01, 2018, 04:21:12 pm »
What your looking is called a Setscrew , a Bolt has an unthreaded portion beneath the head 👍 although VW could still refer to it as a bolt
Last Edit: February 01, 2018, 04:23:14 pm by coolhandluke
Shoduchi
-Given: 220
-Receive: 430
My Ride:
Reply #7 on:
February 01, 2018, 04:36:47 pm »
I've just returned from VW and my bolt is a M8x60 with a inner multipoint head. M12 is the size of the tool to screw it.
I still haven't found the corresponding part number.
I'm going to get a hex collared bolt with the same dimensions, used on manual transmissions: WHT005480.
.:R-Line
Dan_FR
-Given: 132
-Receive: 189
wait...what?
Reply #8 on:
February 01, 2018, 08:30:46 pm »
Helps to know the correct size!! LOL
I'll scour part numbers tonight, be surprised if I dont find it!
Dan_FR
-Given: 132
-Receive: 189
wait...what?
Reply #9 on:
February 01, 2018, 08:35:01 pm »
How about N10724701
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/transmission-mount-screw-m8x60/n10724701/
Shoduchi
-Given: 220
-Receive: 430
My Ride:
Reply #10 on:
February 01, 2018, 10:38:17 pm »
Thanks for your help
@Dan_FR
I saw that too but the lack of a collar made me think it's not adequate for the job.
.:R-Line
MIJ_JAGGER
Won't Shut up.
-Given: 103
-Receive: 79
Reply #11 on:
February 01, 2018, 11:45:25 pm »
Had a look on etka, only M8 is the double stud...sure VW advised you correct?
Shoduchi
-Given: 220
-Receive: 430
My Ride:
Reply #12 on:
February 02, 2018, 12:26:52 am »
Quote from: MIJ_JAGGER on February 01, 2018, 11:45:25 pm
The problem is that ETKA doesn't have a list of the bolts for the DSG clutch housing. There are 18 bolts M8x60 connecting the clutch housing with the DSG itself, and another 3 smaller bolts. You can't find them there. They looked at the bolt and told me the bolt was a M8. I had a M12x55 and a M12x65 to compare with mine. They were much thicker.
The one I ordered is used for the same purpose on manual gearboxes. It's just an hex head bolt instead of a multipoint inner head bolt.
.:R-Line
Dan_FR
-Given: 132
-Receive: 189
wait...what?
Reply #13 on:
February 02, 2018, 07:32:26 am »
To be honest, unless contact/clearance is an issue I'd prefer a high tensile hex head with a washer behind it anyway
Only reason I can think of for it not being available as it's not a serviceable part and the entire thing is supplied new?
Shoduchi
-Given: 220
-Receive: 430
My Ride:
Reply #14 on:
February 02, 2018, 08:49:17 am »
Yeah, DSG aren't serviceable. You can only get a few parts for it: mechatronics, oil pump, clutch pack, speed and temperature sender, oil cooler, etc. Check page 321-059.
I'll let my mechanic the option to use that bolt for manual clutch housings or reuse the old bolt.
.:R-Line
All Things Mk5
Mk5 General Area
