Author Topic: Calipers - S3 8v Will they fit?  (Read 13039 times)
Offline Rob1
  • -Given: 40
  • -Receive: 24
Re: Calipers - S3 8v Will they fit?
« Reply #15 on: March 15, 2018, 09:00:15 pm »
If you got them for as little as £120 it's maybe worth paying a bit extra to get them refurbished with new seals etc.
I got some PP calipers off ebay for a decent price (see main thread) but I've had problems for a while and I'm pretty sure one of the pistons is sticking. Point is, I've spent dead money on fitting the calipers, knackering discs, and now I'm replacing the lot with brand new calipers pads and discs. The calipers coming off will of course be getting a full rebuild before I move them on.
I just think for a little extra cash you can have the peace of mind that you're not going to end up with costly issues. I risked it, and lost out. Lesson learnt!
Any idea what you might sell the PP calipers sell for?
Black Ed30
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #16 on: March 15, 2018, 09:02:22 pm »
No idea yet but depending on the cost of refurb maybe 250-300. I'll make sure they're like new.
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #17 on: March 15, 2018, 09:04:44 pm »
Cheers guys I’ll look into that.
On another note do you guys know if the mk7r discs are a straight swap for the mk5?
With the bigger calipers from the R32/6R/S3/Cupra, yes. With factory fitted calipers on a GTI, no.
Thanks Shoduchi, what was would the following be a straight swap on my mk5 or would I need anything else?
Black Ed30
Offline neilw
« Reply #18 on: March 16, 2018, 09:39:47 am »
Thanks, good, advice. I'm going to be in no rush to put them on the car. My current disks and pads have loads of life left in then. I probably put them to one side until the time comes to r-tech the car.
Edition30 #0002 R-Tech Stage2
Offline neilw
« Reply #19 on: March 16, 2018, 09:42:19 am »
I think you'll just need bigger dust shields (Or whatever they call them)
The Clubsport S disks will go on if you don't mind dropping £300 on them
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #20 on: March 16, 2018, 10:48:38 am »
Black Ed30
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #21 on: March 16, 2018, 10:58:44 am »
You don't need bigger dust shields. It's fine with the factory fitted ones. I'm using 350 mm discs with factory dust shields.
But if you really want to get bigger dust shields you can fit the dust shields from the R32/6R/S3 8P/Cupra 1P.
Offline neilw
« Reply #22 on: March 16, 2018, 02:30:30 pm »
Thanks. That's good to know
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #23 on: March 16, 2018, 06:16:13 pm »
Cheers Shoduchi your a wisdom of knowledge 👍
Black Ed30
Offline Mk5. EWC
« Reply #24 on: March 16, 2018, 09:58:26 pm »
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 79
« Reply #25 on: March 16, 2018, 11:26:00 pm »
No
Offline neilw
Offline Mk5. EWC
« Reply #27 on: March 18, 2018, 09:39:32 pm »
https://www.mtecbrakes.com/brake-discs/audi/s3-2013/s3-2-0-quattro-05-13.html
Vented Diameter: 340.0 Thickness: 30.0 Minimum Thickness: 27.0 Height: 50.0 Bore Diameter: 65.0 Studs: 5
These are 340mm for an S3 does this look like the correct fitment? Want to get these on before my service as brake fluid is due! What brake fluid is recommended for these too.
  • -Receive: 692
« Reply #28 on: March 19, 2018, 03:56:56 pm »
Yep.
Anything DOT4 or DOT5.1 with a decent boiling point will do.
I recommend brake assembly lube with sliding caliper brakes as well.  The proper ceramic stuff, not copper grease.
Offline neilw
« Reply #29 on: March 20, 2018, 10:05:36 pm »
Arrived today, they look good and massive....
One is missing the rubber boots on the slider but that's easily sorted.
« Last Edit: March 20, 2018, 10:09:11 pm by neilw »
