Author Topic: What bolts need replacing for new brake discs?  (Read 3492 times)
Offline pandaman
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,115571.0.html
« on: April 28, 2018, 10:58:10 pm »
I've got myself some new discs and pads, front and rear, that I'm going to fit this week. I'm just not sure which bolts/screws I should definitely be replacing. The caliper carrier bolts? are they the M14 spline/triple square bolts? and maybe the torx 30 that holds the disc to the hub? Just need confirmation, thanks in advance!
Re: What bolts need replacing for new brake discs?
« Reply #1 on: April 29, 2018, 08:41:00 am »
None. You can reuse them all.
Offline pandaman
« Reply #2 on: April 29, 2018, 11:34:48 pm »
Well that makes life simple, cheers!
Offline dronners
« Reply #3 on: April 30, 2018, 10:45:38 am »
might be worth having the screws that hold the discs on handy as a spare. if they come out ok then you can reuse them. but they can be quite easy to mash up
Offline Octoparrot
  • -Receive: 104
« Reply #4 on: April 30, 2018, 04:40:15 pm »
I think the bolts that hold the caliper carriers on are stretch bolts and therefore are meant to be replaced although personally I wouldn't bother as there fairly large and it would take a lot to break them.
The rear carrier bolts are M14 triple squares and are a real pig to get at and are really tight, my advice is to make sure you can loosen these first before you start removing the rear calipers because I failed and ended up taking it to a garage, might save you time dismantling it all only have to put it back together again.
Replacing the bolts that hold the discs on is a good idea as it easy to round the heads on them, I always put some copper slip on the threads of these for easier removal next time.
  • -Receive: 692
« Reply #5 on: April 30, 2018, 11:11:32 pm »
Front carrier bolts aren’t stretchers  :happy2:
Most people reuse all the bolts on the entire car.  The only bolts I won’t risk reusing are the engine mount and subframe bolts.  Ever since an engine dropped out of a car in Italy recently, VAG have come down hard on dealers where stretch bolts are concerned!
« Reply #6 on: May 01, 2018, 12:12:20 am »
^^^ What he said. My bolts are 11 years old and have had 4 different brake kits on them  :signLOL:
Offline pandaman
« Reply #7 on: May 02, 2018, 12:02:57 am »
Cheers guys, now I'm just waiting for it to stop bloody raining!
