Author Topic: Air Con not working....at all.  (Read 9253 times)
Offline Chesto18
« on: July 16, 2018, 07:32:34 am »
Hi,
Getting a bit fed up with my non-working air con in all this heat!
I’ve done a fairly comprehensive search on here and it appears it could be a number of things, but here are my symptoms
Essentially pressing the AC button does nothing at all. No cold air, no change in the temp of the air coming through. Neither fan activates after pressing the switch.
Any ideas where to start? Fuses? Recharge? Pressure switch?
Offline Octoparrot
  • -Receive: 104
Re: Air Con not working....at all.
« Reply #1 on: July 16, 2018, 12:51:57 pm »
My advice is take it to an Air Con specialist (not Kwik fit) and get it properly diagnosed as you say it could be one or several things.
Offline neilw
« Reply #2 on: July 16, 2018, 12:53:46 pm »
Have you had it leak tested? Take it for a re-gas, if it's leaking they won't fill it, and normally not charge you. If you have a fault code reader that may give you some clues as well. The pressure switch can sometimes break, that's about £40 to replace, or the solenoid on the compressor can also fail.
If it's leaked then you can try and find the leak with a UV torch, and then go from there.
Edition30 #0002 R-Tech Stage2
« Reply #3 on: July 16, 2018, 02:57:14 pm »
No gas.
Pressure switch faulty and leaked coolant.
Compressor f*cked.
Most likely to be one of those
Offline Chesto18
« Reply #4 on: July 16, 2018, 07:45:03 pm »
Cheers guys. I think I’ll go down the re-gas route first and see what happens.
Offline mo
« Reply #5 on: July 17, 2018, 11:38:31 am »
Mine is intermitten. Has already been regassed so will replace the pressure switch before going down the compressor route.
Ordered one off Ebay for £10
2007 Ed30 Superchips Bluefin Stg 1
RNS510 & MDI
Offline neilw
« Reply #6 on: July 17, 2018, 12:29:25 pm »
Compressors are readily available on eBay for less than £40 too, if you willing to take a punt on a used one
Offline Cosmos
  • 376bhp 423lbs torque
  • My Ride: Golf Gti Edition 30
« Reply #7 on: July 17, 2018, 08:48:57 pm »
My air con wasnt working recently even although i got it recharged last October.
The fans blew air through the vents,it just wasnt cool.Got the air con pressure switch replaced and another recharge and all is good now.
Offline mo
« Reply #8 on: July 24, 2018, 06:11:01 pm »
Had my pressure switch changed and a regas and now working full time. Though doesn't seem to get as cold as other cars. Maybe that's normal. No complaints here tho
RNS510 & MDI
  • -Receive: 692
« Reply #9 on: July 24, 2018, 06:58:28 pm »
Agreed, it is pretty weak in the MK5, even with everything working properly.  My friends MK7.5 isn’t much colder either.  Must just be a VW thing.
« Reply #10 on: July 25, 2018, 09:57:11 am »
Really? My mk5 gets nice and cold.
Offline slim08
« Reply #11 on: July 25, 2018, 10:31:05 am »
This is a timely post.
My A/C hasn't been working properly... takes 15 mins to get cool(ish) air moving. I bought a re-gas kit online and went to top it up - and the pressure is too high already! I tried giving it a couple small squirts of new gas but didn't proceed any further.
Now the A/C will put out some cooler air, and more quickly, but I think something's wrong... pressure switch, ya'll recon?
  • -Receive: 692
« Reply #12 on: July 25, 2018, 05:58:23 pm »
It does get cold, just not as cold as other cars.  Maybe I’ll stick a thermometer in the vents and see what it’s kicking out.
Offline muff1991
  • -Receive: 70
« Reply #13 on: July 26, 2018, 04:17:36 pm »
My air con in my previous GTI worked but wasn't that cold, i still think to this day something wasn't right, i'd get in other cars and be like... your air con is wicked!
My current GTI air con doesn't work at all... so keeping an eye on this thread, i don't know where to start with process of elimination tbh without wasting money!
  • -Receive: 692
« Reply #14 on: July 26, 2018, 08:01:26 pm »
I must admit, in today’s 35 deg heat, it was very welcome!  After a 20 min journey with it running full blast on LO, it was like stepping off a plane in Hong Kong, so I guess it does work.  Just takes too long (compared to other cars - like Vauxhalls ffs!) to chill the cabin.
First check is vag-com, then gas leaks, then condenser, then pump.  It can get expensive if it’s duff hardware.
